Home > Maintenance & Mods (L322) > Oil leak & bit of smoke :PCV hoses / part numbers? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Fairly straight forward job but it can be fiddly and means laying on top of the engine to get to them. You'll know if they need done if you lift the plastic cover and at the back there are two rubber hoses which run across the top of the engine - if they are squishy then they will all need done and that could be causing the oil leak.
17th Jun 2016 4:49pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Nick - thanks mate , you've been a massive help
17th Jun 2016 5:33pm |
17th Jun 2016 9:29pm |
Hi Steve
17th Jun 2016 9:53pm |
Also the banjo bolt (15) at the bottom is a separate part number - LYG000110 and the washers (16) are LYX000170 Current Fleet:-
17th Jun 2016 9:57pm |
Thanks again mate! How do you find the part numbers ? 2003 Vogue 4.4 V8 Java Black |
18th Jun 2016 6:24am |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
I just did this job.... Had the same problems you described...
18th Jun 2016 9:10am |
Thanks everyone , I've bought all the bits , done the top silicon hoses myself (much much better than the standard crap!) found it was a bit tight attaching them to top of oil separator as they're larger diameter.
2nd Jul 2016 11:45am |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 |
Bump |
1st Nov 2016 6:23pm |
