Home > Maintenance & Mods (L322) > Oil leak & bit of smoke :PCV hoses / part numbers?
Tuts
I've had a recurring oil leak which I thought was from the rocker cover gaskets, these have been replaced but the leak is still there. It's particularly bad in the near side lower part of the engine and covers the drive & stealing gaiters in oil.
With that in mind and the fact I'm getting blue smoke under hard acceleration (but ONLY on hard acceleration) I think it may be the PCV hoses - there's a banjo type joint on a hose down there that's also quite oily too
How many are there and any ideas of part numbers? Is it a big job (how many hours labour would I be expected to pay to replace them)
Thanks in advance
Steve
Ps it's a 2003 4.4 petrol 2003 Vogue 4.4 V8 Java Black
Post #392028 17th Jun 2016 2:42pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Fairly straight forward job but it can be fiddly and means laying on top of the engine to get to them. You'll know if they need done if you lift the plastic cover and at the back there are two rubber hoses which run across the top of the engine - if they are squishy then they will all need done and that could be causing the oil leak.
Those 2 main pipes are
Part 8510366 , LLH000130
Part 8510367 , LLH000140
The other two pipes are a bit lower down and more fiddly
Short fat stubby hose - LLH000110
Long thin hose - LR003814
The parts don't cost much, but I sourced a silicone set which have lasted much longer.
Your blue smoke could be the PCV valve (Part number LKR000040) which should be checkec / changed at the same time
Also the Oil separator / cyclone which will probably be gummed up too - these can sometimes be cleaned or to replace the part number is LLP000010
Plenty of information on the Wiki as to how to replace them. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #392042 17th Jun 2016 4:49pm
Tuts
Nick - thanks mate , you've been a massive help
Cheers Thumbs Up Thumbs Up 2003 Vogue 4.4 V8 Java Black
Post #392054 17th Jun 2016 5:33pm
Tuts
Nick - any idea of part numbers for the oil return pipe shown as no.14? Is it a good idea to replace that too? 2003 Vogue 4.4 V8 Java Black
Post #392087 17th Jun 2016 9:29pm
nicksaab
Hi Steve
I think its LSP500010 - Crankcase Ventilation
Its not a part on mine which I've had problems with so can't really help you, but haven't heard its something which needs routinely replaced- but others might have a different opinion. I guess if the banjo bolt is leaking then it will need doing unfortunately though.
Good luck
cheers
Nick Current Fleet:-
Post #392092 17th Jun 2016 9:53pm
nicksaab
Also the banjo bolt (15) at the bottom is a separate part number - LYG000110 and the washers (16) are LYX000170 Current Fleet:-
Post #392094 17th Jun 2016 9:57pm
Tuts
Thanks again mate! How do you find the part numbers ? 2003 Vogue 4.4 V8 Java Black
Post #392116 18th Jun 2016 6:24am
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
I just did this job.... Had the same problems you described...
Really straight forward... But as Nicksaab said, be prepared to get real intimate with the engine.
I, as most who did this job, had troubles unscrewing the (6 or so) torx headed screws which keep the PCV in place. Most of them get screwed. I my case I had to use an iron saw to get one off.. If you get the PCV off replace the bolts with 10mm hex head screws. The bolts should be 6mm x 1.0 x 25mm.
This page: http://www.pelicanparts.com/techarticles/B...cement.htm is very helpful.
I ordered silicone hoses to replace the top two hoses, and the small oil return hose, also painted the rocker covers when I removed them to replace the gaskets
Also found this site to be very helpful: http://www.realoem.com/bmw/enUS/partgrp?id...&mg=11.
I ordered all of the replacement parts (see partnumbers at realoem) at the BMW dealer, prices being very reasonable. 2002 L322 V8
Post #392130 18th Jun 2016 9:10am
Tuts
Thanks everyone , I've bought all the bits , done the top silicon hoses myself (much much better than the standard crap!) found it was a bit tight attaching them to top of oil separator as they're larger diameter.
Question - once the valve is replaced too (my one is clearly failing as its full of oil Crying or Very sad )
Will the oil leak(s) 'heal' when the crankcase pressure drops back to normal ?? Hoping it will be the end of it - have most people that have replaced the pipes found it cured their leaks? I've already changed the rocker cover gaskets - I hope head gaskets aren't needed too Big Cry 2003 Vogue 4.4 V8 Java Black
Post #394139 2nd Jul 2016 11:45am
DoubleRL322
United States 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Bump
Post #411739 1st Nov 2016 6:23pm
