![]() | Home > Maintenance & Mods (L322) > Oil leak & bit of smoke :PCV hoses / part numbers? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Fairly straight forward job but it can be fiddly and means laying on top of the engine to get to them. You'll know if they need done if you lift the plastic cover and at the back there are two rubber hoses which run across the top of the engine - if they are squishy then they will all need done and that could be causing the oil leak.
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Nick - thanks mate , you've been a massive help
Hi Steve
Also the banjo bolt (15) at the bottom is a separate part number - LYG000110 and the washers (16) are LYX000170 Current Fleet:-
Thanks again mate! How do you find the part numbers ? 2003 Vogue 4.4 V8 Java Black |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
I just did this job.... Had the same problems you described...
Thanks everyone , I've bought all the bits , done the top silicon hoses myself (much much better than the standard crap!) found it was a bit tight attaching them to top of oil separator as they're larger diameter.
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Bump |
