Home > Technical (L322) > Adaptive headlights
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Adaptive headlights
Could I just ask fellow forum members, who have a 2011, with adaptive headlights to check out the start up symbol that shows briefly at ignition. I was told that if it stays on, there is a fault with system. But I note that Stan pointed out in an old post, that if it briefly illuminates orange, there could be a fault. I'm not convinced my adaptive lights are working.
My symbol illuminates briefly orange.
Those with working adaptive lights, does yours illuminate orange or another colour?
One more point, does the light switch need to be in the auto mode for the adaptive lights to work?
Thanks in advance
Post #391657 14th Jun 2016 6:39pm
this is from the owners manual , not much help i'm afraid,
Post #391661 14th Jun 2016 7:26pm
Cavalier
Thanks for that Stan, I've seen that already. My adaptive syble comes on briefly coloured orange at Ignition, I just wondered if that is correct.
Post #391667 14th Jun 2016 8:08pm
mzplcg
That's what my 2011 S/C does and they are working fine.
As far as the AUTO position goes, the only thing I found was that high beam assist doesn't work unless it's in the AUTO position.
Post #391668 14th Jun 2016 8:28pm
Cavalier
Thanks for that, at least I know now that the start up symbol is normal Thumbs Up
Post #391670 14th Jun 2016 9:15pm
Should come on briefly on start up Thumbs Up
Post #391679 14th Jun 2016 11:17pm
GraemeS
I haven't seen any indication that mine are working but no fault symbol either. How obvious are they? I see the corner lights when they're on.
Post #391732 15th Jun 2016 9:50am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Mine comes on everytime I turn the ignition on as with the other warning lights. Mine has come back on afew times but turn ignition off and on again and it sorts itself out.
Easy to test at night, low speed and turn the steering wheel and see if the curb will light up etc...
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #391734 15th Jun 2016 10:11am
GraemeS
Thanks Alex. However mine's corner lights switch on and light-up the kerb whereas the headlights appear to stay straight ahead.
Post #391743 15th Jun 2016 10:52am
GraemeS
I finally confirmed that mine are indeed working, having tracked the apex of the cut-off point while wriggling the steering wheel back and forth a little in a dark area.
Post #397480 24th Jul 2016 8:38pm
