Home > Technical (L322) > Adaptive headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
this is from the owners manual , not much help i'm afraid,
14th Jun 2016 7:26pm |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Thanks for that Stan, I've seen that already. My adaptive syble comes on briefly coloured orange at Ignition, I just wondered if that is correct. |
14th Jun 2016 8:08pm |
That's what my 2011 S/C does and they are working fine.
14th Jun 2016 8:28pm |
Thanks for that, at least I know now that the start up symbol is normal |
14th Jun 2016 9:15pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Should come on briefly on start up |
14th Jun 2016 11:17pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2517 |
I haven't seen any indication that mine are working but no fault symbol either. How obvious are they? I see the corner lights when they're on. |
15th Jun 2016 9:50am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Mine comes on everytime I turn the ignition on as with the other warning lights. Mine has come back on afew times but turn ignition off and on again and it sorts itself out.
15th Jun 2016 10:11am |
Thanks Alex. However mine's corner lights switch on and light-up the kerb whereas the headlights appear to stay straight ahead. |
15th Jun 2016 10:52am |
I finally confirmed that mine are indeed working, having tracked the apex of the cut-off point while wriggling the steering wheel back and forth a little in a dark area. |
24th Jul 2016 8:38pm |
