Home > Maintenance & Mods (L322) > Bonnet Release Cable
Realist
Wales
And if it breaks at the other end and not in the car how am I going to get the bonnet open then? Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #389157 28th May 2016 11:00pm
I believe the only way is to remove the wheel and inner wing on the passenger side (Left Front), "get in there" (or find suitable small person who can), which gives access to the catches, and with tools release the catches.
Make sure you are properly jacked up and supported with axle stands before trying this! .
Post #389158 28th May 2016 11:20pm
They all break in the car... A weak point in the cable near the pull/release... Thumbs Up
Post #389159 28th May 2016 11:31pm
RR2008HSE
^ That's what happened to mine. My first question to the mechanic was, "how did you get the bonnet open?" He explained that the cable broke inside the car, so he just put some vice grips on it and pulled. Bonnet opened.
Post #389165 29th May 2016 12:19am
Realist
Wales
Round two...... Ding, ding.
Having another look now wish me luck lol. Range Rover quotes.....
Post #389180 29th May 2016 8:46am
Realist
Wales
Well thanks guys you lot was smack on the button.
Removed the handle and bracket and yes the resistance I could feel was indeed the spring and yes it had snapped behind the bracket.
All changed.
Massive thanks guys much appreciated indeed for your help and advise. Range Rover quotes.....
Post #389188 29th May 2016 9:46am
Thumbs Up Thumbs Up Thumbs Up
Post #389193 29th May 2016 11:11am
RR2008HSE
Post #389238 29th May 2016 8:23pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Thread resurrection.. but I'm having a similar issue.. when I pull the bonnet lever in the car, only the driver side pops up. The passenger side of the bonnet is still locked. How do I open it? 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #543718 12th Feb 2020 10:21am
TDSIX
Solved..
https://www.fullfatrr.com/forum/topic54762.html 2010 FF 4.4 TDV8 Vogue - Gone
2006 FF TD6 - Gone
Post #545921 3rd Mar 2020 9:25pm
