![]() | Home > Maintenance & Mods (L322) > Trailer Brakes |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
The majority of UK non-commercial trailers have mechanical brakes, the US have electric ones hence the extra hook up.
Never found it on mine Zig. Maybe the connector was tucked up out of the way but I did have all those trims off to get a cable through the bulkhead and I never saw it.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I sorted out my wiring for electric brakes on my 2003, not sure if yours are the same but search on rr.net for all the info. I fitted the brake controller ( Techonsha ) just above the obd2 opening by your right knee. The activation feed is taken from the light control module , lower right pillar close by. Run a wire from the controller to the trailer plug. You then need to sort out the trailer plug wiring and mod the outputs from the trailer module in the right rear wing or when you turn the sidelights on the trailer brakes will come on full strength |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
G'Day Cobbers
Hi Zig, not that I can recall mate. I can check again although I now have a 2011 car which has different looms.
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
Hi, I don't know if post 2006 models are different but for 2003 - 2006 you need to splice into the blue/black wire at connector C0380 pin number 9 on the Trailer Control Module for the Brake signal (or at the other end of this wire at C0937 pin 10 on the main Light Control Module). See here -
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Honestly unsure if it has it or not.
Thanks for all the replies guys,
Well its not there ..............striped bottom part of dash out def not there that answered my question
