Home > Maintenance & Mods (L322) > Trailer Brakes |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
The majority of UK non-commercial trailers have mechanical brakes, the US have electric ones hence the extra hook up.
28th Apr 2016 3:01pm |
Never found it on mine Zig. Maybe the connector was tucked up out of the way but I did have all those trims off to get a cable through the bulkhead and I never saw it.
28th Apr 2016 6:32pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I sorted out my wiring for electric brakes on my 2003, not sure if yours are the same but search on rr.net for all the info. I fitted the brake controller ( Techonsha ) just above the obd2 opening by your right knee. The activation feed is taken from the light control module , lower right pillar close by. Run a wire from the controller to the trailer plug. You then need to sort out the trailer plug wiring and mod the outputs from the trailer module in the right rear wing or when you turn the sidelights on the trailer brakes will come on full strength . All quite easy when you follow the how to`s. One thing I could not sort was the issues with led trailer lights, after many hours I gave up and fitted old school lamps to stop the constant flashing caused by the light module test voltage. It can be done but I put it in the not worth the effort section. 2007 TDV8 VSE
29th Apr 2016 5:59am |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
G'Day Cobbers
29th Apr 2016 7:48am |
Hi Zig, not that I can recall mate. I can check again although I now have a 2011 car which has different looms.
29th Apr 2016 8:49am |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 79 |
Hi, I don't know if post 2006 models are different but for 2003 - 2006 you need to splice into the blue/black wire at connector C0380 pin number 9 on the Trailer Control Module for the Brake signal (or at the other end of this wire at C0937 pin 10 on the main Light Control Module). See here -
4th May 2016 11:41pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Honestly unsure if it has it or not.
5th May 2016 6:49pm |
Thanks for all the replies guys,
5th May 2016 10:42pm |
Well its not there ..............striped bottom part of dash out def not there that answered my question
11th May 2016 11:31am |
