Home > General (L405) > adaptive xenon lights (AFS)
Page 2 of 3 <123>
JMDT
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Corris Grey
Does anyone know if the adaptive headlights/adaptive front/AFS have any external visual differences to the standard xenon lights. Is there anything in the system menu that indicates they are fitted. I would have thought an option to stop them swivelling. On startup, I assume the self test is obvious if you are looking at the car from the front externally? I am used to them on Volvos and they are easy to spot/identify/notice operating when driving... Thanks
Post #389600 31st May 2016 9:01pm
put your vin into here and it will give a build sheet,
http://www.vindecoderz.com/
...and if you have them fitted , it will be obvious when you drive [in the dark].. ... - .- -.
Post #389602 31st May 2016 9:06pm
JMDT
Thanks Stan. My build sheet is not showing on vindecoderz... The vehicle is new so I think not yet loaded.
I drove it in the dark and it wasn't obvious at all. On my Volvo it was obvious... So they are either not fitted or not activated (if they need be activated).
I had a new vehicle delivered in Jan which was ordered with AFS/adaptive xenons. But a factory error meant they weren't fitted. So they built me a new one which I collected on Monday and I am thinking this one also doesn't have them fitted... Big Cry
Anyway it's going back on Saturday to have drivers side door soft close activated, bonnet latch adjusted ... Current: L460 Autobiography D350 2023, Defender D240 HSE 2020, Defender 110 Adventure 2015, Defender 90 XS 2012, Lightweight Ser III 1975, Aston Martin DBS Manual 2008
Previous: L405 SVAutobiography Dynamic 2018, L405 SDV8 Autobiography (2016 x 2, 2015 x1), 110 V8 1989, Discovery td5 ES Series II 2000
Post #389604 31st May 2016 9:34pm
Paul J.
Park facing a wall and turn the steering from side to side. It should be obvious whether or not the beam follows the wheel.
Post #389606 31st May 2016 10:01pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Not too sure I'm on the right track here but if it's what I think you are asking I'm not aware of any visible difference but they do need to be set via the driver menu feature. That way you'll notice them go to full beam automatically, provided there's no on coming traffic and will illuminate around corners when driving slowly and turning.
Post #389607 31st May 2016 10:05pm
JMDT
Thank you ... All makes sense and at moment they don't move when I turn. One to check out with my dealer this weekend ...
Post #389611 31st May 2016 10:32pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Paul J. They don't work when a vehicle is stationary.
When you switch your ignition on you can see the warning light self test - I think its amber for a few seconds. When you put your light switch to Auto (in the dark) you should see the word Auto next to it in green.
It is obvious when you are driving in the dark, especially if you come to a sharp bend or left turn, it should light up the kerb.
You WILL know if you have them!
Post #389624 1st Jun 2016 7:47am
wealy
The menu that Basilfaulty is referring to is for the high beam assist function. But that's a good check, I think you have to have adaptive headlights if you have high beam assist.
Post #389625 1st Jun 2016 7:52am
Emperor Mong
No, I have High Beam Assist and no adaptive headlights.
Post #389671 1st Jun 2016 10:41am
wealy
WOW. Shocked
I thought adaptive and high beam assist were standard on an Autobiography????
Post #389684 1st Jun 2016 1:03pm
caymanblack
High beam assist is standard however adaptive and assist is a £315 option on the AB.
I agree though these really should be standard!
Post #389793 2nd Jun 2016 8:13am
wealy
£315 ? Its a must have at that cost! - Come on LR - make it standard.
Post #389794 2nd Jun 2016 8:18am
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I have adaptive that doesn't test on start up but works fine. I do not have high beam assist though. Is it really standard?
Post #389799 2nd Jun 2016 9:14am
wealy
Don't think high beam assist was on the 322?
Post #389801 2nd Jun 2016 9:18am
Mcnallykev
That'll teach me not to read the title! My Mate has a 322 and has high beam assist. His is well specced though.
Post #389802 2nd Jun 2016 9:20am
Page 2 of 3 <123>
