![]() | Home > General (L405) > New car with dents upon collection |
andyxxx Member Since: 29 Jan 2016 Location: Yorkshire Posts: 23 ![]() ![]() |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2683 ![]() ![]() ![]() |
As said before, this truly beggars belief , they must assume owners are muppets, it's not "character", it's clearly their issue! |
These are pictures of the courtesy car front door. After the repair my car now looks almost identical
Good photos and I would not accept that on a brand new car. I totally agree with you, this has to be sorted properly even if you decide to kick a ball against the door to create the same effect |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
Looks like a ripple where the door skin is bonded to the internal framework |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Yep - I've got them too |
The rear door is harder to photograph as the door skin does curve out slightly towards the back door. However this is supposed to be a gradual sloping out. On my car and on the courtesy car there is a distinctive crease line.
I have just spoken to the dealer - this gets worse:
I guess it depends on the range of 'to some degree' and whether yours is within the normal tolerance.
Is it a dent - or a curve in a panel ? |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Was the law not changed at the end of last year to be more in favour of the purchaser? I'm sure it's easier now to reject a car. Previously..
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
This isn't a hand built vehicle. The doors should all be identical, save for colour or trim. Random variations in parts (ANY parts) seem a lot more like the British Leyland days where parts had only coincidental chances of actually fitting together. Not good. ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Wasn’t the Rover SDi 1 inch longer one side than the other? Good old Rover |
