Home > General (L405) > New car with dents upon collection |
andyxxx Member Since: 29 Jan 2016 Location: Yorkshire Posts: 23 |
3rd May 2016 8:02am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
As said before, this truly beggars belief , they must assume owners are muppets, it's not "character", it's clearly their issue! |
3rd May 2016 8:18am |
These are pictures of the courtesy car front door. After the repair my car now looks almost identical
3rd May 2016 12:32pm |
Good photos and I would not accept that on a brand new car. I totally agree with you, this has to be sorted properly even if you decide to kick a ball against the door to create the same effect MY 2010 5.0 SC Galway green and sand interior!!
3rd May 2016 12:57pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
Looks like a ripple where the door skin is bonded to the internal framework |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Yep - I've got them too
3rd May 2016 1:09pm |
The rear door is harder to photograph as the door skin does curve out slightly towards the back door. However this is supposed to be a gradual sloping out. On my car and on the courtesy car there is a distinctive crease line.
3rd May 2016 1:22pm |
I have just spoken to the dealer - this gets worse:
4th May 2016 12:55pm |
I guess it depends on the range of 'to some degree' and whether yours is within the normal tolerance.
4th May 2016 1:01pm |
4th May 2016 3:02pm |
Is it a dent - or a curve in a panel ?
4th May 2016 3:07pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Was the law not changed at the end of last year to be more in favour of the purchaser? I'm sure it's easier now to reject a car. Previously..
4th May 2016 6:48pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
This isn't a hand built vehicle. The doors should all be identical, save for colour or trim. Random variations in parts (ANY parts) seem a lot more like the British Leyland days where parts had only coincidental chances of actually fitting together. Not good. |
5th May 2016 1:06am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Wasn’t the Rover SDi 1 inch longer one side than the other? Good old Rover |
5th May 2016 7:48am |
