Home > General > L322 v L405 dimensions
i've been overtaken by the L405 a few times and get the impression that its bigger than the L322 that i'm driving so i perused topix and found the dimensions of both..
L322 W,2216 H,1865 L,4967 W-B,2880
L405 W,2220 H,1835 L,4999 W-B,2922
L494 W,2220 H,1780 L,4850 W-B,2923
so the L405 width is roughly the same and the height is lower by 30mm and even the wheel base of the L405 is only 42mm wider, would this give the illusion that the L405 is bigger?
i've also included the L494 dimensions as a comparison.. ... - .- -.
Post #380834 5th Apr 2016 11:49am
I think it's the slightly higher waist line that makes it look bigger, the Ewok looks big on it's own until you put it next to something, and I'm sure that's because it's got a very high waist line... Pete
Post #380849 5th Apr 2016 2:11pm
you could be right there Pete, the L405 bonnet does look higher when next to mine.. Thumbs Up ... - .- -.
Post #380853 5th Apr 2016 2:24pm
With my tyres and in off road setting I can still look down an them Stan.... Laughing
When are you adding 83 to your 322 then??? Pete
Post #380859 5th Apr 2016 3:13pm
Shocked wow - I'm really surprised - I always thought the L494 was L322 size & the L405 was bigger.
Even in the picture at the top left of this page, the L405 looks longer... I wonder if the tapered rear windows add to the effect.
Post #380873 5th Apr 2016 4:57pm
fisha
L405 looks longer cause of the higher leading edge of the bonnet makes the general body shape longer (look at the pic above in top left) . . .the bumpers are similar position, but the bonnet comes further out before cutting down. Similarly, the rear body comes further rearward at the tailgate with less of a step outwards the bumper. So the end to end dimensions are similar, but where the L322 has stepped out bumpers the L405 has less, instead replacing it with longer body panels. You're body panel wise probably gaining about 4cm rear, 4cm front, plus 3cm in overall lenth . . . adds up to at least 10cm longer in body panel along the waistline, which you would visually notice.
Also, the shallower rake of the windscreen visually elongates the front half of the vehicle compared to the L322.
That being said, in real life, the L405 does look and feel bigger than the L322. V8 or else ...
Post #380876 5th Apr 2016 5:07pm
@Pete, when i can add those two numbers together without a calculator.. Laughing ... - .- -.
Post #380877 5th Apr 2016 5:29pm
i'm glad i'm not the only one that thinks the L405 looks bigger.... Thumbs Up ... - .- -.
Post #380880 5th Apr 2016 5:37pm
its all in the shape Stan,
there is a bit of a stretch in the WB length but its less than 2", if you actually park one next to the other then there is not a lot in it, its perception of size rather than actual physical bulk. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #380881 5th Apr 2016 5:39pm
CS
The 405 is a tighter fit to get into a single garage as the mirrors don't fold in as much (2073mm as against 2034). That leaves about 1" on either side in my garage for the 405 - a bit uncomfortable. Only Range Rovers since 1988
Post #380885 5th Apr 2016 6:02pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Doesn't the L405 come in long wheel base option aswell. ?
Giving extra leg room in the rear seats?
Post #380897 5th Apr 2016 7:54pm
yes it does Greg.. ... - .- -.
Post #380898 5th Apr 2016 8:06pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
wow - I must be the only person that thinks the L322 "looks" bigger and has far more road presence than the 405. Shocked
Maybe its the squarer angles.
Post #380966 6th Apr 2016 10:10am
drugs ? All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #380968 6th Apr 2016 10:12am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Size doesn't matter Ner Ner The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #380969 6th Apr 2016 10:13am
