Home > Technical (L322) > Fuel gauge, restricted performance
Billydun34
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Hi guys been having an issue with my fuel gauge reading zero when it is full, seems to start to work again after putting a couple of hundred miles on then if i leave the car for any time goes back to reading zero again this is been happening for a couple of months, but now i am getting a restricted performance message even without starting the car just with the ignition on, i have plugged my iid tool in and its giving me 2 error codesP0480-11(2F) and P138F-22(6C), anyone got any ideas?? i have tried a battery reset procedure but still the same. I have a trip from Aberdeen to Nottingham next week and a bit nervous about driving the car, your help would be greatly appreciated.
Post #375535 3rd Mar 2016 1:43pm
If the codes don't have descriptions with them, email Gap and they will tell you what they mean... Pete
Post #375562 3rd Mar 2016 4:32pm
Billydun34
Thanks Pete i have sent them an email to clarify codes
Post #375565 3rd Mar 2016 4:46pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
A guess at both without any further info.....
Fuel gauge - faulty sender unit (corroded connections) - LR have a recommended 'fix' that costs circa £200 unless you have warranty.
Restricted performance - could be lots of things, but common is water in fuel caused by faulty sensor that requires a new housing replacement.
Needs codes/description though to confirm.
Post #375580 3rd Mar 2016 6:37pm
Billydun34
Thanks i will check that out regarding fuel sender, these are the code definitions from Pat at GAP
P0480 = Fan 1 control circuit.
P138F = Turbocharger boost control position sensor B minimum/maximum stop performance.
Post #375584 3rd Mar 2016 7:06pm
