Home > Technical (L322) > TD6 - Poor Fuel Consumption
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Afternoon all,
I've had my 55plate RR Vogue for around a month now and cant seem to better 17.5mpg. Almost of all my driving is town driving in start and stop traffic but at the same time my work horse Audi A3 diesel is averaging 55mpg doing the exact same.
I've recently had an inspection 2 service and also had the gearbox flush carried out.
Stuck for ideas now. Any help appreciated.
Thanks,
Kris
Post #35391 9th Nov 2010 1:31pm
have it re-mapped kris... ... - .- -.
Post #35394 9th Nov 2010 1:57pm
Fox
17.5mpg sounds more like it's being driven very hard with lead boots, or there is a problem.
May be better to sort that out before remapping. Whistle
Hang on, you didn't say it's diesel... is it petrol?.. in which case that sounds fine.
Post #35397 9th Nov 2010 2:02pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
Re: TD6 - Poor Fuel Consumption
kriswilson wrote:
Afternoon all,
Thanks,
Kris
Doesn't sound that extraordinary.
I have a TD6, My Brother has an Audi A3 2.0 TDI.
I get 18mpg on my commute, he gets around 50 going to near enough the same place.
What do you get on the motorway at 70 ? Mine's around 28.
Andy
Post #35398 9th Nov 2010 2:03pm
td6 in the title fox, i had to look twice for it... ... - .- -.
Post #35401 9th Nov 2010 2:08pm
Fox
Balls. Laughing
Post #35402 9th Nov 2010 2:11pm
kriswilson
Yes its diesel.
I was reading through some of the posts where consumption was mentioned and was seeing figures or early to late 20's for the TD6 which is why i thought i would ask the question.
I drive very very sedately as have a small child in the car 90% of the time, very rarely reach 3000rpm if i'm brutely honest.
Was thinking about getting the EGR valve..? Do you think that could be clogged up? Nothing at all was flagged as being wrong while in the garage last week.
Thanks for all your input ! Thumbs Up
Post #35407 9th Nov 2010 2:41pm
Avi
kriswilson wrote:
Yes its diesel.
It depends how bad the traffic is on your commute. Mine's 10 miles, and takes around an hour!!! I think 18 for me is acceptable, and to be honest i was expecting worse. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #35408 9th Nov 2010 2:51pm
looking on other sites it appears that you might need a soft reset on the gear change ecu [if there is one Exclamation ]...this is done by disconnecting the battery overnight and when the ecu is powered back up it learns your driving technique and should give you better gear change which should result in more mpg....i dont know how true this all is but when i had my remap i was told that it would take 300 miles for the ecu to learn my driving habits so there might be something in it, worth a try... ... - .- -.
Post #35413 9th Nov 2010 3:48pm
kriswilson
Will give it a shot Scarey. I presume if i lock the car the disconnect the battery then when i re-connet tomorrow it will still unlock? Hope it wont loose the pairing. Maybe a silly question Embarassed
Post #35414 9th Nov 2010 3:51pm
i would lock the car manually when you have disconnected the battery , but leave the car untouched for about half hour to get rid of any residual voltage...
btw ,are you first owner if not maybe the car learnt the previous drivers way of driving..[thinking aloud here] ... - .- -.
Post #35416 9th Nov 2010 3:57pm
kriswilson
No, i'm the second owner.
I will try what you've advised tonight and see monitor the change over the coming weeks.
Thanks,
Kris
Post #35419 9th Nov 2010 4:01pm
same as me then, i wonder if my theory is correct.. ... - .- -.
Post #35421 9th Nov 2010 4:18pm
Mojo
2005 Range Rover Vogue Td6 Buckingham Blue
did you guys get anywhere with this?? I seem to get the same fuel consumption in town and on the motorway. I have a TD6 and the display is showing approx 18 to 19mpg.
Post #36342 16th Nov 2010 4:12pm
InVogue
Try resetting the trip computer at 70 mph on the motorway. You should see a reading of 25+ mpg...
Post #36346 16th Nov 2010 4:21pm
