![]() | Home > Technical (L322) > TD6 - Poor Fuel Consumption |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
have it re-mapped kris... ... - .- -.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
17.5mpg sounds more like it's being driven very hard with lead boots, or there is a problem.
Hang on, you didn't say it's diesel... is it petrol?.. in which case that sounds fine. |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Doesn't sound that extraordinary. I have a TD6, My Brother has an Audi A3 2.0 TDI. I get 18mpg on my commute, he gets around 50 going to near enough the same place. What do you get on the motorway at 70 ? Mine's around 28. Andy |
td6 in the title fox, i had to look twice for it... ... - .- -.
Balls. |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Yes its diesel.
It depends how bad the traffic is on your commute. Mine's 10 miles, and takes around an hour!!! I think 18 for me is acceptable, and to be honest i was expecting worse. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it ![]() |
looking on other sites it appears that you might need a soft reset on the gear change ecu [if there is one |
Will give it a shot Scarey. I presume if i lock the car the disconnect the battery then when i re-connet tomorrow it will still unlock? Hope it wont loose the pairing. Maybe a silly question |
i would lock the car manually when you have disconnected the battery , but leave the car untouched for about half hour to get rid of any residual voltage...
No, i'm the second owner.
same as me then, i wonder if my theory is correct.. ... - .- -.
Mojo Member Since: 08 Jan 2010 Location: UK Posts: 15 ![]() ![]() |
did you guys get anywhere with this?? I seem to get the same fuel consumption in town and on the motorway. I have a TD6 and the display is showing approx 18 to 19mpg. |
InVogue Member Since: 03 Nov 2010 Location: Cheshire Posts: 57 ![]() ![]() |
Try resetting the trip computer at 70 mph on the motorway. You should see a reading of 25+ mpg... |
