Home > Technical (L322) > Seat Envy
Wylie66
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
on the left hand seat it is above the back rest switch
 2003 V8 Vogue in Silver
Post #370361 3rd Feb 2016 6:53pm
mjdronfield
Yes, my old memory may be at fault...
From the manual
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #370364 3rd Feb 2016 6:58pm
Brian
This ebay listing shows a pack with the headrest and backrest 4 way switch - the price would probably be why the owner put the wrong one in, I near fell off my chair when I saw it! - I would swear the same headrest switch on mine (2004) looks slightly different (more rounded?) but its dark and wet and i'm not going out to look right now Cool
http://www.ebay.co.uk/itm/Range-Rover-L322...1542808051
Post #370447 3rd Feb 2016 11:46pm
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Driver side and near side of 2003 attached. both same
Post #370485 4th Feb 2016 10:12am
miggit
Right chaps there is the possibility that the whole seat has been swapped for an HSE seat, but I recon that I know how to tell.......... Surely if the HSE seat doesn't have the 4 way head rest switch, you should be able to adjust the height of the headrest manually (or once a year!). So if you can't adjust the headrest manually then it's the switches that are wrong, and if the headrest is adjustable then the seat is wrong Rolling Eyes confused? me too Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #370493 4th Feb 2016 10:54am
makes sense to me Thumbs Up
put the correct panel in and the headrest should work.. ... - .- -.
Post #370502 4th Feb 2016 11:27am
Brian
Yes the pack in mine is the same as Declan's above I was slightly confused as my seat plastics are all black so i thought the lumbar support was part of the pack Confused Anyway I agree also with Stan that if the right switch is in then all should be well and would also assume that the previous owner probably decided he/she did not need to move the headrest so took the cheaper option. you should be able to pick up a switch from a breaker, hopefully one who does not use ebay and knows what they cost Laughing
Post #370514 4th Feb 2016 12:16pm
