Home > Technical (L322) > Seat Envy |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 |
on the left hand seat it is above the back rest switch
3rd Feb 2016 6:53pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7790 |
Yes, my old memory may be at fault...
3rd Feb 2016 6:58pm |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
This ebay listing shows a pack with the headrest and backrest 4 way switch - the price would probably be why the owner put the wrong one in, I near fell off my chair when I saw it! - I would swear the same headrest switch on mine (2004) looks slightly different (more rounded?) but its dark and wet and i'm not going out to look right now
3rd Feb 2016 11:46pm |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
Driver side and near side of 2003 attached. both same
4th Feb 2016 10:12am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Right chaps there is the possibility that the whole seat has been swapped for an HSE seat, but I recon that I know how to tell.......... Surely if the HSE seat doesn't have the 4 way head rest switch, you should be able to adjust the height of the headrest manually (or once a year!). So if you can't adjust the headrest manually then it's the switches that are wrong, and if the headrest is adjustable then the seat is wrong confused? me too Yesterday I couldn't spell Engineer... Today I are one!
4th Feb 2016 10:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
makes sense to me
4th Feb 2016 11:27am |
Yes the pack in mine is the same as Declan's above I was slightly confused as my seat plastics are all black so i thought the lumbar support was part of the pack Anyway I agree also with Stan that if the right switch is in then all should be well and would also assume that the previous owner probably decided he/she did not need to move the headrest so took the cheaper option. you should be able to pick up a switch from a breaker, hopefully one who does not use ebay and knows what they cost |
4th Feb 2016 12:16pm |
