![]() | Home > Technical (L322) > Seat Envy |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
on the left hand seat it is above the back rest switch
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Yes, my old memory may be at fault...
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
This ebay listing shows a pack with the headrest and backrest 4 way switch - the price would probably be why the owner put the wrong one in, I near fell off my chair when I saw it! - I would swear the same headrest switch on mine (2004) looks slightly different (more rounded?) but its dark and wet and i'm not going out to look right now |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Driver side and near side of 2003 attached. both same
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Right chaps there is the possibility that the whole seat has been swapped for an HSE seat, but I recon that I know how to tell.......... Surely if the HSE seat doesn't have the 4 way head rest switch, you should be able to adjust the height of the headrest manually (or once a year!). So if you can't adjust the headrest manually then it's the switches that are wrong, and if the headrest is adjustable then the seat is wrong |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
makes sense to me |
Yes the pack in mine is the same as Declan's above I was slightly confused as my seat plastics are all black so i thought the lumbar support was part of the pack |
