Home > Maintenance & Mods (L322) > Major engine oil leak 4.4 TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
The supplying garage has seen the video and is asking questions of the garage that said they'd fixed the "slight leak".
25th Jan 2016 6:57pm |
It's been to my local Indy today for diagnosis and they changed a rubber o ring under the oil filter housing that should be round and was flat. They cleaned all the old oil off the back of the engine then did an oil change..... But the car is still there as now they suspect a seal on the oil cooler that's sat in the V of the engine and will need a strip down to get to. Not sure they can start the work this week so I'm guessing I'll be without it for a couple of weeks....
1st Feb 2016 5:36pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8516 |
thats a right PITA, at least the dealer is picking up the tab! all for about 50p in o rings..... There is nothing that can't be fixed with a hammer😜😜
1st Feb 2016 6:32pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
I have had an oil leak on mine too. Fixed under warranty, told an o ring on a breather. A few weeks later saw it was still leaking, back to dealer and told different leak caused by oil rail guard or something. Did nt make sense to me, apparently there is a service bulletin in it. Called today saying still leaking and it's a job that requires the engine out and four days!! Will report back but I am expecting some resistance from LRs approve used warranty people but it's hardly wear and tear!! It's a 2012 now with 50k miles. 2012 4.4TDV8 VSE
3rd Aug 2016 6:10pm |
Mine was proved to be the oil heat exchanger that sits in the V. A common issue as the garage has now done another 9 since mine.....
3rd Aug 2016 6:20pm |
Car still at dealers and not yet started. Approved warranty would nt agree as leak not severe enough! Their engineer is coming this week. Car going to be off road at least another week. I bought this car with the planning of keeping it years. Late versions of each generation of Range Rover seem to get a premium 10 years on and I went for a 2012 and a high spec. After this I am not sure I have the confidence to keep it long term. So much to go wrong! Will update later. 2012 4.4TDV8 VSE
7th Aug 2016 4:25pm |
Bar a new wiper motor, mines been fine since..... Don't get disheartened.... the warranty chaps are causing your grief now, not the car .... That just needs the repair......
7th Aug 2016 4:31pm |
Thanks.m and good point. My TD6 which I had for 8 Years and drove 100k miles in was actually very reliable! It's an expensive repair under warranty that probably involves £20 of parts. 2012 4.4TDV8 VSE
7th Aug 2016 4:35pm |
Did you know if the sump needs removing you have to take the engine out on 4.4tdv8? 2012 4.4TDV8 VSE
10th Aug 2016 4:48pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Hallo together, a client of me has the same problem like MJDRONFIELD at his 4.4 TDV8 03/2011, 313hp, he lives in London City until this month, comes back last week to Germany, today I make service, and: what a surprise, great oil leak exactly like on video from MJDR, the client got new EGR in London from indy..., but he never comes back to London. So I must repair, has anyone an idea??
21st Dec 2016 5:35pm |
Hi, as I mentioned above, mine was the oil/water heat exchanger in the V of the engine. It is what they have instead of the traditional oil cooler....Is a common fault. It cracks. Was definitely not the EGR so that must have been to fix a different fault.
21st Dec 2016 6:15pm |
@mjdronfield, you have 100% correct tip, today I build out the old oilcooler, also was little part of oil in the coolantwater, will go on monday to the dealer for buying the part, in 24hours it will be here in Düsseldorf. See at my p
31st Dec 2016 4:12pm |
31st Dec 2016 4:51pm |
All done! Tomorrow will clean the underfloor and change coolant and so on..., will report next week, if all is correct.... (or new leaks). Best wishes for 2017, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
4th Jan 2017 8:10pm |
