Home > Maintenance & Mods (L322) > Major engine oil leak 4.4 TDV8
mjdronfield
The supplying garage has seen the video and is asking questions of the garage that said they'd fixed the "slight leak".
They are happy for me to get the issue fixed at my normal garage and will cover the cost.... And reimburse for the oil I bought.....
Just need to get it sorted now. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #368877 25th Jan 2016 7:57pm
That's good Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #368882 25th Jan 2016 8:22pm
mjdronfield
It's been to my local Indy today for diagnosis and they changed a rubber o ring under the oil filter housing that should be round and was flat. They cleaned all the old oil off the back of the engine then did an oil change..... But the car is still there as now they suspect a seal on the oil cooler that's sat in the V of the engine and will need a strip down to get to. Not sure they can start the work this week so I'm guessing I'll be without it for a couple of weeks....
Peachy this buy a new car thing.....
Dealer is sorting the bill but he needs an idea first and at the moment it's a bit like "how long is a piece of string".
I hope it gets sorted or I'll be having a different conversation....spent all weekend polishing it.... Piggin 'ell 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #369942 1st Feb 2016 6:36pm
thats a right PITA, at least the dealer is picking up the tab! all for about 50p in o rings..... There is nothing that can't be fixed with a hammer😜😜
Post #369957 1st Feb 2016 7:32pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I have had an oil leak on mine too. Fixed under warranty, told an o ring on a breather. A few weeks later saw it was still leaking, back to dealer and told different leak caused by oil rail guard or something. Did nt make sense to me, apparently there is a service bulletin in it. Called today saying still leaking and it's a job that requires the engine out and four days!! Will report back but I am expecting some resistance from LRs approve used warranty people but it's hardly wear and tear!! It's a 2012 now with 50k miles. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #399036 3rd Aug 2016 7:10pm
mjdronfield
Mine was proved to be the oil heat exchanger that sits in the V. A common issue as the garage has now done another 9 since mine.....
The oil is cooled by the water, so when it busts the oil goes in to the coolant, so it all has to be flushed out.... 4 or 5 times. Part is about �400, so cost just over �1000 all in.....
They did the work in a day, no engine out, just worked from above.
Yours could obviously be a different issue.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #399040 3rd Aug 2016 7:20pm
666tur
Car still at dealers and not yet started. Approved warranty would nt agree as leak not severe enough! Their engineer is coming this week. Car going to be off road at least another week. I bought this car with the planning of keeping it years. Late versions of each generation of Range Rover seem to get a premium 10 years on and I went for a 2012 and a high spec. After this I am not sure I have the confidence to keep it long term. So much to go wrong! Will update later. 2012 4.4TDV8 VSE
Post #399528 7th Aug 2016 5:25pm
mjdronfield
Bar a new wiper motor, mines been fine since..... Don't get disheartened.... the warranty chaps are causing your grief now, not the car .... That just needs the repair......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #399529 7th Aug 2016 5:31pm
666tur
Thanks.m and good point. My TD6 which I had for 8 Years and drove 100k miles in was actually very reliable! It's an expensive repair under warranty that probably involves �20 of parts. 2012 4.4TDV8 VSE
Post #399531 7th Aug 2016 5:35pm
666tur
Did you know if the sump needs removing you have to take the engine out on 4.4tdv8? 2012 4.4TDV8 VSE
Post #399977 10th Aug 2016 5:48pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo together, a client of me has the same problem like MJDRONFIELD at his 4.4 TDV8 03/2011, 313hp, he lives in London City until this month, comes back last week to Germany, today I make service, and: what a surprise, great oil leak exactly like on video from MJDR, the client got new EGR in London from indy..., but he never comes back to London. So I must repair, has anyone an idea??
Best rgs and thanks a lot! Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #419044 21st Dec 2016 6:35pm
mjdronfield
Hi, as I mentioned above, mine was the oil/water heat exchanger in the V of the engine. It is what they have instead of the traditional oil cooler....Is a common fault. It cracks. Was definitely not the EGR so that must have been to fix a different fault.
Hope this helps you.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #419057 21st Dec 2016 7:15pm
Meerbusch
@mjdronfield, you have 100% correct tip, today I build out the old oilcooler, also was little part of oil in the coolantwater, will go on monday to the dealer for buying the part, in 24hours it will be here in D�sseldorf. See at my p
ictures, also I will buy two new o-rings 9.00mm x 1.80mm Viton. Will Report in the next week.
Wish you all a good and health 2017, best rgs, Uli
Post #420381 31st Dec 2016 5:12pm
mjdronfield
Happy New Year to you too. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #420397 31st Dec 2016 5:51pm
Meerbusch
All done! Tomorrow will clean the underfloor and change coolant and so on..., will report next week, if all is correct.... (or new leaks). Best wishes for 2017, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #421179 4th Jan 2017 9:10pm
