![]() | Home > Maintenance & Mods (L322) > Major engine oil leak 4.4 TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
Well, I picked it up last Tuesday. Before collection the garage had the mot done and there were advisories on a slight oil leak. They said it was sorted and they'd done a service. I took it to my local Land Rover dealer this morning for a brake hose recall and they told me it had a major engine oil leak and sent me a video.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
first thoughts are a loose or badly fitted oil filter.. ... - .- -.
Thanks gents.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Aparently not easy to get to |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
It seems to me that you've had / have a few issues with this car - surely the dealer needs to sort it ??
There is an engine oil feed pipe into the back of the EGR with a 10p oil ring seal that fails... Just a pointer for you if the oil filter housing is good... A video boroscope helps track these type of leaks down sir... |
Thanks. I don't think it's a wrong un as the other bits are sorted bar the mirror glass, and that wasn't the cars fault. Juddering was rear wheel balancing.
Not saying it's a wrong un mark, probably just stuff which wasn't noticed by the former keeper, most folks aren't as diligent as us forum types |
I put about 2 litres of oil in to get it to the max level. I know it holds 9....
Ok..... It's still on Max...
make sure to check when warm according to the manual. 3.6 cold, 4.4 warm for some reason. There is nothing that can't be fixed with a hammer😜😜
That's what I did. Never had one without a dipstick so followed the instructions.....
If I'm right the type of fitting CTC is talking about is a plastic push on one, with a squeeze release on either side, the rubber o rings in them can compress and leak, I have a similar though less messy leak on the one for the bottom of the dip stick tube on mine. I think you can just pop the o ring out an replace with one of the correct size, so if it is that which is leaking at least the parts bill would be small. |
Thats the one Mr NMJ |
