Home > Technical (L322) > New Windscreen Glass Needed
forever
Had autoglass around to fix a stone chip, but its too big so need a new screen. The fitter said it would be a pilkington screen. just need to check it has all the OEM bits (acoustic, green tint, heated etc), anything else i should watch out for??
Post #366076 8th Jan 2016 3:29pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Rain sensor
Post #366084 8th Jan 2016 4:04pm
SingeRRS
There are a load of posts on the RRS website relating to screens - the advice is you need to get an OEM screen no matter how much autoglass whinge or try and say the screen is equivalent.
There are a number of instances of non-oem screens prematurely cracking or breaking because they have not been manufactured to the original LR specification - even though in some instances they have been made by the same manufacturer. Replacing a screen is a pretty big exercise, pulling off bits of trim etc, so better to do it only once?
Post #366108 8th Jan 2016 4:49pm
Foulolron
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Had mine replaced Tuesday this week by autoglass - was a non LR stamped but made by pilkington with same code numbers, tinted / heated etc - trims fitted back on with new clips - so far (3 days in) no problems wipers work (but better than before) on auto
Post #366127 8th Jan 2016 6:06pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Always wondered... how do rain sensing wipers work ?
Post #366136 8th Jan 2016 7:51pm
DaveK
Post #366137 8th Jan 2016 7:51pm
google says,
Post #366138 8th Jan 2016 7:58pm
Pilkington make the screens for LR so it will be ok.
I had a Pilks screen fitted by Autoglass and it was spot on. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #366139 8th Jan 2016 8:04pm
johnboyairey
Have you considered, your insurance policy...normally comprehensive policies..you only have to pay your excess. So it makes sense to choose a policy, with a smaller excess, if you have a nasty chip, coming up to your mot...
Post #366145 8th Jan 2016 8:46pm
Hairball
England 2006 Range Rover Vogue TDV8 Java Black
Whats the average price peeps are paying if having to
Post #366158 8th Jan 2016 10:08pm
steadyaway
Mine was £75. Make sure it is fitted correctly though. I had to have mine changed as the previous one (also a replacement one before I bought the car) had been fitted too low and was touching the body. As the shell flexed the screen cracked in the lower right hand corner. The fitter struggled to get the wire through that cuts the sealant.
Post #366163 8th Jan 2016 10:55pm
forever
70 for me 25 if they could have repaired the chip
Post #366170 9th Jan 2016 12:13am
forever
Post #366169 9th Jan 2016 12:13am
steadyaway
Heard you the first time......... Very Happy
Post #366171 9th Jan 2016 12:22am
forever
It's the beer the second time Wink
Post #366174 9th Jan 2016 12:58am
