Home > General > Front side lights
Page 2 of 4 <1234>
iT LAD
No tints though....
Post #34957 5th Nov 2010 9:53am
V8 VOGUE
2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Thumbs Up Got them fitted but one of the plastic screw type fixings broke!! Censored
Can i buy these over the counter??
Im happy with the result though thanks .
Post #35108 7th Nov 2010 1:52pm
M44K TS
Do you mean the big White plastic nuts that hold the sidelight unit in? If so they're about 4 quid from LR, I wouldn't advise driving with one of the nuts missing though, that's how I lost one of my sidelights on the motorway. I'd say at least use a couple of washers and 2 nuts as a temporary measure. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #35110 7th Nov 2010 2:12pm
M44K TS wrote:
Changed mine to these...
http://cgi.ebay.co.uk/8-LED-SIDE-LIGHT-BUL...1922wt_827
Will these work on 2002/3 model? Currently, one side is very dim, both very yellow. .
Post #35116 7th Nov 2010 3:20pm
M44K TS
Yeah, they're the ones I have, make sure they're can-bus compatible so they don't throw a bulb error message up. 2006 Mercedes CLS
Post #35126 7th Nov 2010 4:48pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Stone the crows!
I bought a set and fitted them... grand they are to.
Last night I went to go to work for the night shift.. put the key in the ignition and turned on... whats this.. strobes reflecting off the garage door alternate sides of the car.. about five cycles and then stopped.. I'd got no further than switching on the ignition and not flicked any lights on.
Turned off ignition and switched on again.. sure enough cycled the alternating strobe effect from the side lights, about four or five cycles from each side. I can only assume its the I-Bus senting a low voltage to check for bulb failures.. normally not enough to light the standard bulbs but sufficient voltage to light the LEDs.
Have to say it may raise questions when I come out of work given every other car has legitimately fitted strobe lights Laughing
Haven't experimented further but suspect it must do it every time ignition is switched on.. just never noticed in the day light and due to not running the FFRR due to the gearbox declining health. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #36303 16th Nov 2010 12:10am
its only the RR checking the lighting system ...i've had my leds in for months and that happens as well.. ... - .- -.
Post #36305 16th Nov 2010 8:22am
M44K TS
Mine too, perfectly normal. 2006 Mercedes CLS
Post #36397 16th Nov 2010 7:17pm
V8 VOGUE
I ordered some plastic nut retainers for the front side lights and the are as you said only £4 each!!
I only noticed my side lights flashing when i was getting fuel, i just tell peple its something to do with the alarm...... cant be bothered to explain!!
Post #36525 17th Nov 2010 2:07pm
good FFRR attitude .. Thumbs Up ... - .- -.
Post #36527 17th Nov 2010 2:10pm
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
Mine arrived today - so I shall be breaking something on my FFRR tomorrow morning.. Smile
Post #36892 19th Nov 2010 4:54pm
Just fitted mine (see M44KTS ebay link) this morning. No warnings, no flashing yet.
Wow though, what a difference. The old "analog" bulbs were both completely shot and silvered over, hence why so dim. They can go into the box for trips to Europe.
Now to fit blue light tubes under the side steps Laughing .
Post #37083 20th Nov 2010 12:04pm
nice one joe, they really do make a big difference especially on these dark nights... ... - .- -.
Post #37084 20th Nov 2010 12:14pm
dubbs
Fitted. So they don't look quite as good during the day as being a 2007 you can see the bulb/led unit but who really looks that hard at a headlight (aside from flies for a very brief and rather terminal moment in their lives)
Question... what is the other bulb sharing that unit? It's not a sidelight, foglight or a main bulb so what on earth is it? I tried all the buttons and switches I could think of and none of them lit the bulb up....
Anyone? Come on... show me how daft I am as I can't believe it's an unused bulb in there....
Post #37128 20th Nov 2010 4:33pm
you got adaptive lighting dubbs? ... - .- -.
Post #37156 20th Nov 2010 5:06pm
Page 2 of 4 <1234>
