Home > Technical (L322) > Voltage readings.
Page 1 of 5 12345>
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Voltage readings.
Good morning.
I am thinkin that me alternator is failing.
Volts
On tickover = 13
Driving = 12.9/13.
I have a power drain when 'off and locked'
New battery.
Thursday while motorway cruising at 71mph the transfer box fail came up every 20secs or so then it tried a few times to go into safe mode.
When I slowed doon everything back to normal
Fluids changed and no leaks or heat probs.
I am getting the fast indicator flash at times and sporadic warnings of lights failing when all is ok.
So, could alternator be failing?
It has done 185k miles.
I have read somewhere that the light module in drivers footwell could be sus.
Ideas please.
Thanx in advance.
Bill Made in Scotland frae 'Girders'
Post #363042 20th Dec 2015 11:52am
Sounds like alternator to me, you will probably find the battery will need swapping to, they don't like not getting enough charge and sulk a lot....
Power drain is a different ball game..... Pete
Post #363047 20th Dec 2015 12:39pm
With those voltage readings whilst driving I think your alternator is failing too. Thumbs Up
The voltage drain you say you are experiencing could be related.
I would be inclined to either get it checked or changed as a matter of urgency.
Post #363048 20th Dec 2015 12:39pm
Lost for Words
Stick the multimeter on AC and see what you get. My bet is the diodes are failing and causing the current drain also. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #363050 20th Dec 2015 12:44pm
Bofa Bill
Thank yer.
Alternator ordered
Part of me is thinkn that if the alternator is failing then maybe its causing a wee drain
Anyways, new alternator from Santa on its way.
I will update when done
Ah how big a job is replacing it? I cant even see it. Made in Scotland frae 'Girders'
Post #363051 20th Dec 2015 12:44pm
Looks like about a 3can 2knuckle job to me..... Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #363058 20th Dec 2015 1:38pm
Bofa Bill
Gawd that has depressed me somewhat
Rather a big'sh job.
Thank you for posting the info
Big Cry Made in Scotland frae 'Girders'
Post #363072 20th Dec 2015 2:28pm
Zirconblue
Assuming your earth straps are sound, i'd go with faulty alternator too.
Post #363082 20th Dec 2015 3:31pm
Bofa Bill
Thank you for all the replies.
I went for a short drive last neet and reading was a steady 13.8.
I Still think alternator is reaching the end of its life
185,000 miles and 13 years so I can't complain
Now, I have been reliably informed that the ecu thingy in the drivers footwell can also throw up all the ghost faults that I have been getting.
Does anyone have any idea on its name please?
I now have a 200 mile trip home today which will prob be on a truck.
Not looking forward to it.
Post #363233 21st Dec 2015 10:13am
I think you may be referring to the headlight self levelling ecu which can cause problems through getting damp.
It was located at low level behind the passenger side footwell side panel.
You car may or may not have this fitted as the self levelling system was discontinued by LR as it simply didn't work.
What are you using to check the voltage whilst driving?
Post #363256 21st Dec 2015 11:42am
Bofa Bill
I am using a plug in volt meter
I dont suppose its 100% but gives me an an idea within a few volts.
I dont have leveling headlamps
Update.
Managed 100miles and decided to get recovered.
Kept going in and out of failsafe mode which put me into damage limitation mode as I was about to hit the A34 in rush hour.
Got back to my mechanic chappy who put it onto his PC reader.
Not surprising it lit up like a xmas tree.
Scratch head time to work oot best way forward.
He cleared failts and car went perfect for 10miles with knly one short 'ding' and a flash of trans box in neutral on the screen.
Post #363356 21st Dec 2015 8:06pm
Due to low voltage I expect, new alternator, charge battery, clear faults and normal service should resume.... Thumbs Up Pete
Post #363359 21st Dec 2015 8:29pm
Bofa Bill
Thank you for yer time and the pm's
I have new alternater in the post so get that changed as a first stop Made in Scotland frae 'Girders'
Post #363368 21st Dec 2015 8:43pm
steptoe
Bill
The ECU you're talking about is the lighting ECU. In the drivers footwell behind the R/H panel as you say.
Usually causes strange indicator/lighting problems. Mine also caused radio/stereo problems when it decided to act up.
Post #363452 22nd Dec 2015 11:16am
Bofa Bill
Thanx Stepto, radio???
Jings, forgot aboot that.
Radio cr4p so one more to the list of pointers to that LCM?
Indicators flashing fast
Various bulb failure messages
Radio
Voltage drain
Post #363453 22nd Dec 2015 11:18am
Page 1 of 5 12345>
