![]() | Home > Off Topic > AA Parts and Garage Cover, any good ? |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Does sound good but I bet the hoops you have to go through to get it make it unworthy but hope not as it's the AA Many thanks
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
It's like any insurance product - at an aggregate level, they intend make money - there will be more in premiums than they pay out.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
What can you fix on a Ff for less than �500...... In parts and labour......
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
Covers anything except wear and tear items (brakes, tyres etc) spoke to the guy on the phone and he was saying springs and shocks are all covered as well ( I don't have a FF anymore )so yeah a proper fix plus you don't actually need to break down at the side of the road if you get a non start or problem on the driveway you can call them out and they will diagnose the problem and if they are unable to fix it there and then it would be arranged to have it taken to either an AA approved garage or just any independent as long as they are VAT registered and if the bill is over �500 you can put the rest towards it. I have been doing some research online and its mostly good things I'm reading to be honest. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
Done a few repairs for the AA Claims. As long as the patrol attends the car, and makes an initial diagnosis, they can tell whether the failure is a covered item or not
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I also 'think' that the insured vehicle has to be fully maintained in accordance with manufacturer's specifications AND servivced at an authorised garage with the service book stamped so DIY'ers won't qualify.......... |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 ![]() ![]() ![]() |
I've had the aa breakdown and repair cover for 3 years. It's been great. I've had a few things done through it. Battery, ecu module, that hedgehog part behind dash, and both front suspension airbags. Even if the aa get you going again like when the battery went flat they will have a new battery put on if that's the problem or replace the part which is causing the drain at a garage of your choosing. The land rover battery was �450 ish so only cost me �25. Same with both airbags at the front, �25 each. Bargain. 2003 Range Rover HSE 3.0 TD6
