Home > Off Topic > AA Parts and Garage Cover, any good ?
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Im going to be taking out AA roadside cover and i noticed their Parts and Garage Cover option. it adds about £70 per year onto the policy and pays unto £500 parts and labour it can be claimed five times per year.
Seems a pretty good deal but just wondering if its too good to be true ? Has anyone one here had any experience with them that would recommend it ?
cheers Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #362641 17th Dec 2015 5:41pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Does sound good but I bet the hoops you have to go through to get it make it unworthy but hope not as it's the AA Many thanks
Paul
Post #362652 17th Dec 2015 6:50pm
It's like any insurance product - at an aggregate level, they intend make money - there will be more in premiums than they pay out.
So I guess it depends whether you feel lucky - or rather unlucky - in that you will break down and they won't be able to fix it at the roadside - and will need to take it to a garage who will charge more than £70 to get it back up and running - and that happens every year......
Does it cover a proper repair, or just enough of a fix to get you to your destination ?
Post #362654 17th Dec 2015 7:06pm
What can you fix on a Ff for less than £500...... In parts and labour......
Not much is the answer. If anything big goes wrong then you aren't covered such as turbos and gearbox. And anything smaller than £500 in p&l should be fairly straight forwards in any case! Turbo hoses and the like are patch able and cheap to replace.
Brake components are easily stripped and short of a completely knacked calliper they will be able to fix it at the roadside, would save the £70 if it was me. Or buy a more comprehensive warranty. There is nothing that can't be fixed with a hammer😜😜
Post #362658 17th Dec 2015 7:14pm
markcaughey
Covers anything except wear and tear items (brakes, tyres etc) spoke to the guy on the phone and he was saying springs and shocks are all covered as well ( I don't have a FF anymore )so yeah a proper fix plus you don't actually need to break down at the side of the road if you get a non start or problem on the driveway you can call them out and they will diagnose the problem and if they are unable to fix it there and then it would be arranged to have it taken to either an AA approved garage or just any independent as long as they are VAT registered and if the bill is over £500 you can put the rest towards it. I have been doing some research online and its mostly good things I'm reading to be honest. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #362661 17th Dec 2015 7:30pm
Mikey
Done a few repairs for the AA Claims. As long as the patrol attends the car, and makes an initial diagnosis, they can tell whether the failure is a covered item or not
The repairer then confirms diagnosis, and phones for authority
As said though, £500 doesn't cover a massive amount on an FF, but it's better than nothing Thumbs Up
Post #362688 17th Dec 2015 10:26pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I also 'think' that the insured vehicle has to be fully maintained in accordance with manufacturer's specifications AND servivced at an authorised garage with the service book stamped so DIY'ers won't qualify..........
Post #362690 17th Dec 2015 11:13pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I've had the aa breakdown and repair cover for 3 years. It's been great. I've had a few things done through it. Battery, ecu module, that hedgehog part behind dash, and both front suspension airbags. Even if the aa get you going again like when the battery went flat they will have a new battery put on if that's the problem or replace the part which is causing the drain at a garage of your choosing. The land rover battery was £450 ish so only cost me £25. Same with both airbags at the front, £25 each. Bargain. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #362910 19th Dec 2015 12:46pm
