Home > Maintenance & Mods (L322) > replaced the torque converter |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
torque converter started vibrating slipping and snatching ,so ordered a recon of ebay on thurs afternoon took it to my mates garage stripped it and managed to get the box back in by 5 oclock with just a couple of bolts ,finished it friday,totally different to drive alot smoother,having red up on recon torque converters ,rang a guy named doug ,he knows his stuff ,recons them with uprated kevler plates and give 2 years warrenty. |
6th Dec 2015 12:29pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Don't suppose you took lots of useful photos of the strip down and rebuild for others to follow? .
6th Dec 2015 10:36pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Also where is Doug and how do others find their way to him ...... |
6th Dec 2015 11:13pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Probably worth pointing out that the torque converter lock-up clutches for the TD6 and the V8 models are completely different. The TD6 GM unit is similar to a manual gearbox clutch friction plate assembly with a sprung centre for torsional vibration absorption, so is relatively straightforward to remove and replace.
7th Dec 2015 12:15am |
no photos as i was in hospital when it was being done the torque converter was brought of ebay of a bloke called doug he is bmwe39man,his number is 07802504000 |
7th Dec 2015 5:24pm |
