Home > Maintenance & Mods (L322) > Squeaking noise |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Bearing squeal? Tensioner and idle bearings could be at fault. |
5th Jun 2018 10:26am |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
Thanks for the reply.
5th Jun 2018 11:09am |
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 |
Hi, did you get to the bottom of this ? Mine has very similar, only when cold, within a few mins it's gone. I had a listen this morning & thought it might be one of the belt pulleys but hard to pin point. |
7th Oct 2018 7:19pm |
It was the tensioner which needed doing and had the 2 belts done at the same time. The spring had stretched so for the cost, having it all done seemed the best thing to do. |
7th Oct 2018 7:50pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Could just be the belt put a little talc powder on belt and see if if stops it if it does then change the belt |
7th Oct 2018 10:35pm |
Well I eventually got round to getting this squeaking noise fixed, the noise was getting worse & the service & mot was due so made sense to get it sorted at the same time. Independant specialist diagnosed belt tensioner but advised replacing both belts & idler pulleys too. Anyway I picked her up yesterday & started her from cold this morning to no horrible squeaking noise 😁
12th Feb 2019 7:33pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
The constant prayer of FFRR owners! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
12th Feb 2019 8:45pm |
