Home > Maintenance & Mods (L322) > replaced the torque converter
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
torque converter started vibrating slipping and snatching ,so ordered a recon of ebay on thurs afternoon took it to my mates garage stripped it and managed to get the box back in by 5 oclock with just a couple of bolts ,finished it friday,totally different to drive alot smoother,having red up on recon torque converters ,rang a guy named doug ,he knows his stuff ,recons them with uprated kevler plates and give 2 years warrenty.
Post #360669 6th Dec 2015 12:29pm
Don't suppose you took lots of useful photos of the strip down and rebuild for others to follow? Wink .
Post #360782 6th Dec 2015 10:36pm
Dolphinboy
Also where is Doug and how do others find their way to him ...... Thumbs Up
Post #360789 6th Dec 2015 11:13pm
RRPhil
Probably worth pointing out that the torque converter lock-up clutches for the TD6 and the V8 models are completely different. The TD6 GM unit is similar to a manual gearbox clutch friction plate assembly with a sprung centre for torsional vibration absorption, so is relatively straightforward to remove and replace.
On the other hand, repair of the LUC used in the ZF Sachs converter from early petrol models is a highly specialised task where the reaction plate for the piston springs – which double as tangential driving straps - has to be re-welded back into position very accurately (it’s friction welded at the factory) because the total piston movement is only around 1mm.
The friction plate is a separate item.
For this reason many TC repair shops will not touch the ZF unit.
Phil
Post #360798 7th Dec 2015 12:15am
cowman
no photos as i was in hospital when it was being done the torque converter was brought of ebay of a bloke called doug he is bmwe39man,his number is 07802504000
Post #360893 7th Dec 2015 5:24pm
hgbosch
South Africa
Hi All
My gearbox was fully rebuilt with all Sonnax mods done. But the local TC rebuilds in SA are questionable at the very best for the GM 5L40E boxes. So the TC failed within 3 months.
I have now elected to fit a new TC from BMWE39Man (Doug).
What a difference to drive that vehicle now. Well done Doug will give your name to all requesting advise on 5L40E rebuilds.
Doug's TC's use a Kevlar lining in the TC lockup clutch and have other strengthened mods done to them. And they come with a 2 year warranty.
BMWE39MAN
Douglas Lawrence
5 Fron Haul
LL15 1JD Ruthin, Denbighshire
UK
Phone:07802504000
Email:bmwe39@mail.com
Post #504985 12th Feb 2019 11:04pm
