Home > In Car Electronics (L322) > CD changer replacement - one for GAP possibly |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Ł600 ish Pete |
30th Nov 2015 1:43pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Looks interesting. Also that the CD player can be retained if wanted. As I understand it it is inserted in the MOST circuit at any point so if all one wanted to do was use a USB stick it could be inserted in the boot so avoiding all the stripping out to get to the CD? Personally all I want is to be able to play music from USB and a large one (they quote up to 64Gb) would fill the bill and avoid any inconvenience of having to frequently change the USB. All the other requirements - phone etc - are adequately cover by the standard system for me. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
30th Nov 2015 1:54pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
so this russian thingy costs 229 euros which is about Ł161....shipping is 6 euros... ... - .- -.
30th Nov 2015 3:17pm |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
Looks interesting, but my Charman is not up to deciphering the fitting instructions.
30th Nov 2015 5:09pm |
its plug and play steve.. ... - .- -.
30th Nov 2015 5:40pm |
Steve, The optical circuits pass through each element in the line so unplug one side of one.
30th Nov 2015 6:09pm |
30th Nov 2015 6:10pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
That's how I read it too. I would take out the 6cd changer and replace with this, you could also plug in a Bluetooth USB dongle to get Spotify etc from your phone.. |
30th Nov 2015 6:13pm |
Doh!
30th Nov 2015 6:17pm |
Ack-cherly, I thought at first it was Plug 'n Play (he said, trying to sound convincing ), but I started to have doubts when I saw pics like these in what I assumed were the installation instructions:
30th Nov 2015 6:35pm |
Just had a look at the instructions (Google's Jairman was enough to understand ). It appears that if the CD unit is retained the new unit must be installed between the CD player and the head unit. If it isn't retained the new unit can be installed anywhere in the circuit.
2nd Dec 2015 3:46pm |
I hadn’t dared say any more as I bow down to the superior knowledge of forum members , but when I Google-translated the instructions linked to the pics above (my 2nd post d. 30/11), it seemed to me to be all about having to split the MOST cabling and didn’t seem to be Plug ’n Play at all. In addition, I can see in the product photos only one MOST socket.
2nd Dec 2015 4:00pm |
If you remove the CD player then one MOST connector for the new unit would be sufficient. The MOST connectors on the RR optical circuit have two fibre optic cables going into them. One carries the signal into the unit it is connected to and the other carries it away into the system (for want of a better description). IIRC the direction of travel is marked on the connector.
2nd Dec 2015 4:47pm |
2nd Dec 2015 5:14pm |
