Home > Wheels & Tyres > the old tpms chesnut |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
Did you replace a the monitor in the wheel arch or the one in the wheel itself ?
10th Nov 2015 6:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
i did the same as Alistair...i had random warnings for no reason so i switched it off.. ... - .- -.
10th Nov 2015 6:50pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
It was neither, I replaced the TPMS ECU in the boot area. The Jaguar dealer I worked at did try to disable the system but the technician was not able to with the T4 system. |
10th Nov 2015 6:51pm |
So exactly how do you turn it off? |
10th Nov 2015 6:52pm |
buy an iidtool... ... - .- -.
10th Nov 2015 6:53pm |
OK. So are there different makes and if so what one would you suggest or recommend?
10th Nov 2015 6:56pm |
https://www.gap-diagnostic.com
10th Nov 2015 6:59pm |
Thanks Alistair, I will look into them. |
10th Nov 2015 7:07pm |
If you don't need to do much else - it may be worth trying to find someone close to you that has one as you can add additional vehicle unlock codes for £60 |
10th Nov 2015 7:19pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Ours doesn't seem to have TPMS (it appears to have standard rubber valves). I thought they all had it unless owners take their own steps and nobody's touched ours. |
10th Nov 2015 7:45pm |
maybe the previous owner had them removed because of problems.. ... - .- -.
10th Nov 2015 8:04pm |
Alistair, thanks for the suggestion. I will start my search. |
10th Nov 2015 8:08pm |
TPMS was always an option right up until legislation made it compulsory in 2014. That said a lot of 2010 onwards models seem to have it but the later cars seem more reliable. I was never sure quite why the BMW system never made it to LR vehicles though. That works off the ABS sensors and detects if a wheel is turning faster than the others which would indicate low tyre pressure. Much more reliable from what I've seen. |
10th Nov 2015 8:10pm |
I have a 2013 L405 without TPMS
10th Nov 2015 8:17pm |
