Home > Wheels & Tyres > the old tpms chesnut
Classic888
Hi all, I know this is an old annoying problem that has been discussed before, but I am now at a loss what to do. Initial fault was the intermittent yellow warning light on and a message saying "check all tyre pressures". So after doing all the suggested tests and checks I today collected a new TPMS Module. Fitted it and all was OK for 10 mins or so and about 5-6 miles, then the yellow light came on and the message "Tyre Pressure Monitoring System Fault" flashed up, stayed on for a while then went off. Yellow light on all the time.
2007MY Supercharged RHD.
Any further suggestions greatly appreciated.
Post #356121 10th Nov 2015 7:38pm
Did you replace a the monitor in the wheel arch or the one in the wheel itself ?
How did you know which one to replace ?
I got so sick of mine that I bought an IID tool & disabled it
Post #356122 10th Nov 2015 7:42pm
i did the same as Alistair...i had random warnings for no reason so i switched it off.. ... - .- -.
Post #356125 10th Nov 2015 7:50pm
Classic888
It was neither, I replaced the TPMS ECU in the boot area. The Jaguar dealer I worked at did try to disable the system but the technician was not able to with the T4 system. Crying or Very sad
Post #356127 10th Nov 2015 7:51pm
Classic888
So exactly how do you turn it off?
Post #356128 10th Nov 2015 7:52pm
buy an iidtool... ... - .- -.
Post #356129 10th Nov 2015 7:53pm
Classic888
OK. So are there different makes and if so what one would you suggest or recommend?
Thanks
Post #356130 10th Nov 2015 7:56pm
https://www.gap-diagnostic.com
The BlueTooth one is worth the extra Thumbs Up
Post #356132 10th Nov 2015 7:59pm
Classic888
Thanks Alistair, I will look into them.
Post #356133 10th Nov 2015 8:07pm
If you don't need to do much else - it may be worth trying to find someone close to you that has one as you can add additional vehicle unlock codes for £60 Thumbs Up
Post #356135 10th Nov 2015 8:19pm
pld118
Ours doesn't seem to have TPMS (it appears to have standard rubber valves). I thought they all had it unless owners take their own steps and nobody's touched ours.
Post #356142 10th Nov 2015 8:45pm
maybe the previous owner had them removed because of problems.. ... - .- -.
Post #356145 10th Nov 2015 9:04pm
Classic888
Alistair, thanks for the suggestion. I will start my search.
Post #356146 10th Nov 2015 9:08pm
mzplcg
TPMS was always an option right up until legislation made it compulsory in 2014. That said a lot of 2010 onwards models seem to have it but the later cars seem more reliable.
I was never sure quite why the BMW system never made it to LR vehicles though. That works off the ABS sensors and detects if a wheel is turning faster than the others which would indicate low tyre pressure. Much more reliable from what I've seen.
Post #356147 10th Nov 2015 9:10pm
I have a 2013 L405 without TPMS Thumbs Up
Agree on the BMW point - we have an 05 Mini that has been super reliable
Not only is the LR system flaky, but the valves themselves seem very susceptible to corrosion Evil or Very Mad
Post #356148 10th Nov 2015 9:17pm
