![]() | Home > In Car Electronics (L322) > Rearview mirror mount for dashcam |
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 ![]() ![]() ![]() |
Anyone found a rearview mirror mount for a dashcam to fit the 2010MY?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
This is the only stuff I've found that keeps mine in place |
Thanks, Craig. I was hoping that someone would have already solved this problem, but I might well end up going down that route.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
both my front cams are attached by double sided 3m tape and have yet to fall off.. ... - .- -.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I agree with Stan - same with my dash cam mounts
I do wish I could agree - tried it but it only lasted 3-4 days, hence trying to move on to a mirror bracket.
I tried all sorts of stuff including car mirror pads & superglue - the No More Nails tape is the only thing that worked for me |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Have a look at LOCA adheasive, get it on ebay cheap plus you need a UV torch...
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Another +1 for me on the 3M sticky pads/tape - I use it for the Go-Pro mounts on the bike and motorbike helmets as well.
billyvine Member Since: 31 Dec 2015 Location: boston Posts: 1 ![]() |
You can just use a UV flashlight to cure LOCA glue, they are very cheap on amazon. Here is more info on http://vkrepair.com/loca-glue/ |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I think you're either using the wrong type of sticky pads or you're not cleaning the glass well enough before applying it, ie with alcohol or thinners - any oil, tar, silicone or wax on there and it just wont last. A lot of rear view mirrors are just stuck on with double sided tape and last the life of the car. It really needs to be automotive sticky pads, as a lot of the home DIY type ones can;t cope with the temperature range. |
