Home > In Car Electronics (L322) > Rearview mirror mount for dashcam
scotbruce
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Anyone found a rearview mirror mount for a dashcam to fit the 2010MY?
I bought a G1WH, which I love, but, 6 months and 2-3 different failed suction/tape mounts later, I'm looking for a rearview mirror mount that will fit the extremely short rearview mirror stem - and failing miserably! My latest purchase of an Armotek Snakemount is still too wide to fit the narrow (& 8mm) gap behind the mirror.
There must be something out there that can be re-purposed to this end - surely??
Thanks in advance for any suggestions!
Post #355785 8th Nov 2015 12:32am
Can you not screw something to the black plastic rear view mirror cover? When you sell the car, simply buy a new piece of trim! Cant cost too much!
Post #355789 8th Nov 2015 12:45am
This is the only stuff I've found that keeps mine in place Thumbs Up but mine sticks directly to the windscreen
Post #355820 8th Nov 2015 10:47am
scotbruce
Thanks, Craig. I was hoping that someone would have already solved this problem, but I might well end up going down that route.
The WM isn't that helpful/detailed, though I was wondering if there might be any way of lengthening the horizontal stem even by an inch? If not, I'll have to look at securing it to the rear of the mirror/clamping it over the mirror in some way.
I've tried a few things, Alistair, but none have worked and of course the alarm goes off when it falls off the windscreen, hence my determination to go for a mirror bracket of some kind!
Any and all thoughts welcome!
Post #355823 8th Nov 2015 11:31am
both my front cams are attached by double sided 3m tape and have yet to fall off.. ... - .- -.
Post #355854 8th Nov 2015 2:32pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I agree with Stan - same with my dash cam mounts
Post #355871 8th Nov 2015 4:50pm
scotbruce
I do wish I could agree - tried it but it only lasted 3-4 days, hence trying to move on to a mirror bracket.
I'll need to look further to find something that can be re-purposed and that will fit and grip the @8mm gap. There must be something ...
Confused
Post #355891 8th Nov 2015 7:17pm
I tried all sorts of stuff including car mirror pads & superglue - the No More Nails tape is the only thing that worked for me
Post #355896 8th Nov 2015 8:34pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have a look at LOCA adheasive, get it on ebay cheap plus you need a UV torch...
https://en.wikipedia.org/wiki/Liquid_optically_clear_adhesive 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #355936 9th Nov 2015 8:49am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Another +1 for me on the 3M sticky pads/tape - I use it for the Go-Pro mounts on the bike and motorbike helmets as well.
But the G1WH is a different design hanging down from a suction mounts rather than my Blackvue which is stuck directly onto the windscreen using the sticky pads. I can see why you are having problems with getting it to stick to the windscreen given it hangs below the mount and will be always applying a downward force on the sucker.
Only idea I can come up with is if you tried to invert it so the suction mount is below the camera, like a phone mount on the windscreen - but I doubt that will help and would rely on being able to change the orientation on the lens. So suspect I haven't helped at all! Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #356003 9th Nov 2015 9:20pm
billyvine
You can just use a UV flashlight to cure LOCA glue, they are very cheap on amazon. Here is more info on http://vkrepair.com/loca-glue/
Post #364729 31st Dec 2015 11:44pm
Zirconblue
Confused
I think you're either using the wrong type of sticky pads or you're not cleaning the glass well enough before applying it, ie with alcohol or thinners - any oil, tar, silicone or wax on there and it just wont last. A lot of rear view mirrors are just stuck on with double sided tape and last the life of the car. It really needs to be automotive sticky pads, as a lot of the home DIY type ones can;t cope with the temperature range.
Post #364750 1st Jan 2016 2:57am
