Home > Technical (L322) > Reduced Engine Performance message |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Suggest you get a code reader. Over the long term it will pay for itself Howard
7th Nov 2015 8:04pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1031 |
Thanks, but that's way too technical for me! I'd struggle to understand it. |
7th Nov 2015 8:07pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7947 |
Tried Searching ? |
7th Nov 2015 8:30pm |
Yes. Lots of comments about petrol V8s which don't help, plus a couple of comments about split turbo hose, which is apparently an easy fix. I was asking the members on the off chance one of them might have experienced something similar. |
7th Nov 2015 8:45pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
How much fuel was in it? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
7th Nov 2015 8:46pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 |
Three thoughts from experience, could be first sign of alternator failing, battery having a dead cell or I agree with the last comment, check your fuel level. Have had all three on a previous car. Hope these help. Rehab is for quitters!!!
7th Nov 2015 10:41pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Is it a 3.6 or a 4.4 you are enquiring about sir? They both have a set of individual problems, but would need to know which model you have? |
7th Nov 2015 11:27pm |
And if its a 3.6 have you already checked & eliminated the hoses ?
8th Nov 2015 9:33am |
Thanks for all the replies.
8th Nov 2015 12:27pm |
Usually with the turbo / intercooler hoses, the car goes into limp mode. It's also fairly easily recreated - just accelerate really hard - you will usually also see a trail of black smoke.
8th Nov 2015 7:43pm |
Car went to the dealers and they plugged it in. Turns out its one of the EGR valves, which they will replace. Price for the work was £698 all in, covered by LR extended warranty. I did ask if both sides should be done, but the warranty only covers the failed part, so the second would be down to me, so I'll leave it. |
12th Nov 2015 8:21pm |
How much extra would both sides have been - any saving in doing 2 together ?
12th Nov 2015 8:31pm |
The dealer said only one had failed, so no point doing both. I said Sod's law would mean the other would fail soon afterwards, but the dealer said that would be unusual in his experience. To be honest, I'm not that fussed, because if the other one does go, I'm still covered by warranty. Of course many on here will say I should have got both done at the same time! |
12th Nov 2015 9:25pm |
Interesting to see what happens to your turbo now? As they have a funny habit of going BANG very soon after changing EGR’s... Especially if its the N.S. Bank EGR... |
12th Nov 2015 10:39pm |
