Home > Technical (L322) > Reduced Engine Performance message
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
So, I'm driving home after a good day's shooting and I get the message "Reduced Engine Performance". Nothing seemed untoward, engine still pulled, kick down not noticeably different and happily cruised up the A21 at 70. I've had the message on the Freelander 2 I had before the FF, and then it was VERY noticeable and that time the problem was the DPF (the car was 4 months old at the time!)
It was raining and I'd been through a couple of puddles, but there was nothing to give a clue anything was amiss. Engine pulled strongly and yesterday it got a long motorway run, so I can't see it being a DPF issue.
All very odd; I'm going to take it to my trusted dealer, but wondered whether anyone else had experienced anything similar.
Cheers
Andy
Post #355762 7th Nov 2015 8:55pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Suggest you get a code reader. Over the long term it will pay for itself Very Happy Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #355763 7th Nov 2015 9:04pm
Andy S
Thanks, but that's way too technical for me! I'd struggle to understand it.
Post #355765 7th Nov 2015 9:07pm
Tried Searching ? Whistle
Post #355766 7th Nov 2015 9:30pm
Andy S
Yes. Lots of comments about petrol V8s which don't help, plus a couple of comments about split turbo hose, which is apparently an easy fix. I was asking the members on the off chance one of them might have experienced something similar.
Post #355767 7th Nov 2015 9:45pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
How much fuel was in it? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #355768 7th Nov 2015 9:46pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Three thoughts from experience, could be first sign of alternator failing, battery having a dead cell or I agree with the last comment, check your fuel level. Have had all three on a previous car. Hope these help. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #355779 7th Nov 2015 11:41pm
Is it a 3.6 or a 4.4 you are enquiring about sir? They both have a set of individual problems, but would need to know which model you have?
Post #355784 8th Nov 2015 12:27am
And if its a 3.6 have you already checked & eliminated the hoses ?
Were you doing anything particularly different at the time - accelerating hard for example ?
Did the warning disappear or did you just ignore it and keep driving ? Or restart the car and it went away ?
Has it only happened once ?
The value of searching is you can tell us what you've checked already & eliminated Razz
Post #355817 8th Nov 2015 10:33am
Andy S
Thanks for all the replies.
Mine is a 3.6 TDV8, 2010MY. There was around half a tank of fuel on board and I was driving normally on country roads. There was a lot of standing water following heavy rain earlier in the day and I had driven through puddles to remain on my side of the road as vehicles approached from the opposite direction. The warning appeared, but there was no noticeable change in engine performance. I drove on carefully, and on joining a dual carriageway eased the speed up gradually to 65-70 mph, again with no apparent difficulty. When I got home, I stopped the engine, restarted after a few seconds and the message returned. I switched off again, left it for about 30 secs then restarted, and no message came on. That said I only had the engine on long enough to lower the suspension to access mode (as I always do when parking up).
The battery is what was in the car when I bought it at 3 years old. Has never caused any problems before and the car always starts on the first push of the button. It has 60k miles on it, used 95% of the time on long journeys with long periods of not being used, often over a week. I wouldn't know how to check turbo hoses, but a bit of digging around suggests this might be the issue. I'll contact my dealer tomorrow and book it in. I've still got a LR warranty, so hopefully that will cover it!
Post #355848 8th Nov 2015 1:27pm
Usually with the turbo / intercooler hoses, the car goes into limp mode. It's also fairly easily recreated - just accelerate really hard - you will usually also see a trail of black smoke.
There's a guide here for checking & replacing - it's a quick & easy job, but your hands will get quite dirty.
The fact that you didn't lose power sounds like it maybe something different.
It could be a spurious fault caused by a battery issue - they do tend to start throwing up random fault messages as they are on the way out - and 5 years is about right for needing a replacement.
Sounds like you're doing the right thing though - if you have a LR warranty, then let them have a look & diagnose Thumbs Up
Post #355897 8th Nov 2015 8:43pm
Andy S
Car went to the dealers and they plugged it in. Turns out its one of the EGR valves, which they will replace. Price for the work was £698 all in, covered by LR extended warranty. I did ask if both sides should be done, but the warranty only covers the failed part, so the second would be down to me, so I'll leave it.
Post #356538 12th Nov 2015 9:21pm
How much extra would both sides have been - any saving in doing 2 together ?
I have no idea whether they tend to fail in pairs, but think I'd have done both.
Post #356544 12th Nov 2015 9:31pm
Andy S
The dealer said only one had failed, so no point doing both. I said Sod's law would mean the other would fail soon afterwards, but the dealer said that would be unusual in his experience. To be honest, I'm not that fussed, because if the other one does go, I'm still covered by warranty. Of course many on here will say I should have got both done at the same time!
Post #356559 12th Nov 2015 10:25pm
Interesting to see what happens to your turbo now? As they have a funny habit of going BANG very soon after changing EGR’s... Especially if its the N.S. Bank EGR... Rolling Eyes
Post #356577 12th Nov 2015 11:39pm
