![]() | Home > Technical (L322) > Fuelling - slow |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
sounds like the fuel guard has been activated...there should be a plastic yellow thing in the boot that can reset it...should be info in the owners manual re this.. ... - .- -.
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Flipping marvellous there is such a thing, great stuff will read up on it thanks a lot. Many thanks
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
I get this! Really annoying! Happens at my local co op! I've checked to see if my guard had been deployed, no luck!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Turn the nozzle upside down, should then fill better. |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
+1 for turning nozzle upside down, really struggled when I first got mine but fills a treat now |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3150 ![]() ![]() ![]() |
This happened to our old 2007 TDV8.
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
L322 seems worse than most other LR's. It won't accept the commercial pumps nozzle as well, filler neck is just too narrow. A pain really, a proper car should be able to accept fuel properly. Wonder if we could replace the filler neck and pipe with a proper sized one, and without the fuel guard. Is all markets/years the same? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Car's don't accept commercial pump nozzles, they make the commercial pump nozzles incompatible on purpose so you don't put it in lock the trigger on and walk away and have it spewing diesel all over the forecourt. They're designed to be sold to numpties.
All great info thanks all, looks like upside down is the way forward, pretty crap though. Many thanks
it sounds more like a problem with a specific garage than your car. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
Can also happen if the nozzle has been slightly deformed through use causing turbulence which triggers the shutoff. John
or from being driven over. |
You just got the model intended for downunder, hence the nozzle upside down works |
PeterY Member Since: 01 Feb 2015 Location: Oxfordshire Posts: 21 ![]() ![]() ![]() |
Mines the same doesn't matter what angle you put the nozzle you can only pull the trigger half way or it will click off, never a quick stop for fuel for me unfortunately. 2009(10MY) 3.6 TDV8 Vogue
