Home > Technical (L322) > Fuelling - slow
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Fuelling - slow
Could I ask does your RR take forever to fill, the pump clicking every few seconds ?
I've tried all manner of angles and different garages yet can barely get past half fill speed.
Question Many thanks
Paul
Post #355475 5th Nov 2015 4:39pm
sounds like the fuel guard has been activated...there should be a plastic yellow thing in the boot that can reset it...should be info in the owners manual re this.. ... - .- -.
Post #355478 5th Nov 2015 4:45pm
Pvw10
Flipping marvellous there is such a thing, great stuff will read up on it thanks a lot. Many thanks
Paul
Post #355480 5th Nov 2015 4:47pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
I get this! Really annoying! Happens at my local co op! I've checked to see if my guard had been deployed, no luck!
Then at other garages it fills no problem!!!
It's a Land Rover !!!!!!!!!!! 2014 vogue se
Post #355507 5th Nov 2015 7:08pm
Turn the nozzle upside down, should then fill better. Thumbs Up
It's annoying as I can fill the toyotas at the HGV pumps in about 30 seconds flat Shocked There is nothing that can't be fixed with a hammer😜😜
Post #355509 5th Nov 2015 7:27pm
Robgosty
+1 for turning nozzle upside down, really struggled when I first got mine but fills a treat now Thumbs Up
Post #355513 5th Nov 2015 7:41pm
dhallworth
This happened to our old 2007 TDV8.
The filler hose had collapsed and was causing problems filling. There was a service bulletin out to the dealers about it. I printed it and showed them it when it was serviced and it was replaced FOC. Thumbs Up
Post #355532 5th Nov 2015 10:51pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
L322 seems worse than most other LR's. It won't accept the commercial pumps nozzle as well, filler neck is just too narrow. A pain really, a proper car should be able to accept fuel properly. Wonder if we could replace the filler neck and pipe with a proper sized one, and without the fuel guard. Is all markets/years the same? Rolling Eyes Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #355538 5th Nov 2015 11:33pm
Zirconblue
Car's don't accept commercial pump nozzles, they make the commercial pump nozzles incompatible on purpose so you don't put it in lock the trigger on and walk away and have it spewing diesel all over the forecourt. They're designed to be sold to numpties.
If it's only a particular garage that keeps clicking out, then it's more likely just the pumps at that garage have had their shut off calibrated a bit too finely. Tipping it upside down helps, as does pulling the nozzle back out slightly. You can also mention it to the staff, if they get several complaints they'll get the pump manufacturer back out to test them.
Post #355552 6th Nov 2015 12:41am
Pvw10
All great info thanks all, looks like upside down is the way forward, pretty crap though. Many thanks
Paul
Post #355616 6th Nov 2015 9:42pm
Zirconblue
it sounds more like a problem with a specific garage than your car.
Post #355621 6th Nov 2015 11:12pm
Weegie
Can also happen if the nozzle has been slightly deformed through use causing turbulence which triggers the shutoff. John
GAP iiD BT-Sold
Post #355706 7th Nov 2015 2:11pm
Zirconblue
or from being driven over.
Post #355707 7th Nov 2015 2:16pm
ebajema
You just got the model intended for downunder, hence the nozzle upside down works Rolling with laughter MY 2010 5.0 SC Galway green and sand interior!!
Post #355727 7th Nov 2015 4:06pm
PeterY
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Mines the same doesn't matter what angle you put the nozzle you can only pull the trigger half way or it will click off, never a quick stop for fuel for me unfortunately. 2009(10MY) 3.6 TDV8 Vogue
2004 BMW M3 CSL
Post #355742 7th Nov 2015 5:18pm
