![]() | Home > Technical (L322) > help identify this issue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8413 ![]() ![]() ![]() |
Usually cam cover gaskets does that.... have a good look at them..... |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
What colour is the oil? (Could be difficult to identify engine oil if you had recently done changed all the oils at Craig's recently?
Gear and transfer box and both diffs oils done not engine oil.
I always taste them, you get to know after a while what tastes like what.... easiest way to do it... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Trans fluid for the V8/ZF box is straw colour AFAIK - IMHO - I could be wrong Howard
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1427 ![]() ![]() |
Correct, the esso stuff for the ZF box is a golden yellow colour. V8 or else ... |
Good to know that, as I can narrow my search around the transfer box, still guessing a seal has decided to fail |
Looking like it's the rear engine oil seal weeping, not gear box or gaskets as back of engine is nice and clean.
Whip the box out on the drive... it's easy... |
Hmmm I know, I just got the box flushed at Craigs too |
I'd take it back and complain, "since you did my gearbox the engine leaks" sounds fare to me.... |
I agree with Miggit our company Landcruiser we had in Lagos had more issues than my not super reliable 4.2.
