![]() | Home > General > Engine failsafe and air susp inactive/HDC |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
i have in my garage around my bike , they are like a fat sock.Moisture Absorbing Silica Gel ..you can get them from motor bike shops...you could put one in the rear quarter, but if you are getting that much moisture then check under your spare wheel for any water, you may have a leaky seal or you air compressor my be throwing out water... V8 facelift Range Rover Autobiography 22" wheels.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
morning nick, moisture in the car can be alleviated a bit by having the a/c on all the time and as for the loss of power, my eldest thinks it could be the injector ecu [new battery?] or the injectors blocking up.. i hope this helps ... ... - .- -.
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Thanks all. Does having the air con on all the time effect mpg much?? might try throwing some injector cleaner in to see if this makes a difference and am going to splash out on a new battery. Will let you know the outcome. Fingers crossed!! |
i dont think it'll make that much difference nick..certainly cleaning the injectors wont do no harm.. ... - .- -.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
My MKIII sat nav died due to damp in the rear compartment. I pulled it apart and you could see where there had been moisture on the circuit board.
Finally got round to buying and fitting a new battery today!!
Well a day and a half with different lenght journeys ( used to get it more on short journeys) and no pings and all the dash lights!! Could i be speaking to soon?? Sat nav screen still slow to come on when cold though!! I can live with the slow screen if suspension works as it should again!! |
my screen comes up slow as well nick so nothing to worry there mate...good news re the errors etc.. ... - .- -.
Keeping fingers crossed.. oh and promise will get those pics up soon! Sold the other side headlight on Ebay for £170 so you got a bargain |
good price nick.. |
Oh well, 3rd day and joy oh joy all the lights and chimes are back!! tc, ABS , suspension inactive, engine failsafe message.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Took 3 days for your new battery to discharge, Alternator? 2004 black Vogue TD6 |
As alreadnty mentioned - you should leave the A/C on, if you dont all electrical copper connectors will fur up which reduces the voltage they can carry or interups the data signals on the data bus.
Surley alternator would eventually result in dead battery. Had this prob for a while but never had issue starting/ or low battery related problems . Will get alternator tested. Is there a certain voltage the RR should achieve?? |
