Home > General > Engine failsafe and air susp inactive/HDC
Page 2 of 4 <1234>
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Also, how do you prevent moisture in rear compartment as have started to have delayed sat nav screen since the cold / damp weather!!
Post #34166 28th Oct 2010 9:00pm
daveo
i have in my garage around my bike , they are like a fat sock.Moisture Absorbing Silica Gel ..you can get them from motor bike shops...you could put one in the rear quarter, but if you are getting that much moisture then check under your spare wheel for any water, you may have a leaky seal or you air compressor my be throwing out water... V8 facelift Range Rover Autobiography 22" wheels.
Post #34181 28th Oct 2010 10:34pm
morning nick, moisture in the car can be alleviated a bit by having the a/c on all the time and as for the loss of power, my eldest thinks it could be the injector ecu [new battery?] or the injectors blocking up.. i hope this helps ... ... - .- -.
Post #34197 29th Oct 2010 9:03am
Nickj
Thanks all. Does having the air con on all the time effect mpg much?? might try throwing some injector cleaner in to see if this makes a difference and am going to splash out on a new battery. Will let you know the outcome. Fingers crossed!!
Post #34327 29th Oct 2010 7:46pm
i dont think it'll make that much difference nick..certainly cleaning the injectors wont do no harm.. ... - .- -.
Post #34330 29th Oct 2010 7:53pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
My MKIII sat nav died due to damp in the rear compartment. I pulled it apart and you could see where there had been moisture on the circuit board.
Definately fit something to soak up the condensation. This area of the boot is supposed to house the vent that draws the cabin air out by the wheel arch though how I don't know.
I got a MK 4 nav as a result but worry about the same thing happening again. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #34331 29th Oct 2010 8:14pm
Nickj
Finally got round to buying and fitting a new battery today!!
Lets wait and see......................
Post #36578 17th Nov 2010 8:02pm
Nickj
Well a day and a half with different lenght journeys ( used to get it more on short journeys) and no pings and all the dash lights!! Could i be speaking to soon?? Sat nav screen still slow to come on when cold though!! I can live with the slow screen if suspension works as it should again!!
Post #36757 18th Nov 2010 8:33pm
my screen comes up slow as well nick so nothing to worry there mate...good news re the errors etc.. ... - .- -.
Post #36758 18th Nov 2010 8:35pm
Nickj
Keeping fingers crossed.. oh and promise will get those pics up soon! Sold the other side headlight on Ebay for £170 so you got a bargain Laughing Wink
Post #36763 18th Nov 2010 8:48pm
good price nick.. Thumbs Up ... - .- -.
Post #36764 18th Nov 2010 8:49pm
Nickj
Oh well, 3rd day and joy oh joy all the lights and chimes are back!! tc, ABS , suspension inactive, engine failsafe message.
Waste of money on the battery. Really tainting joy of ownership.
Guess its time to book it in to a specialists.
Got a violent wheel wobble when cornering at 70-80 (seemed front left) as well tonight! Related maybe??
Post #37218 20th Nov 2010 8:15pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Took 3 days for your new battery to discharge, Alternator? 2004 black Vogue TD6
Post #37221 20th Nov 2010 8:27pm
dan_uk_1984
As alreadnty mentioned - you should leave the A/C on, if you dont all electrical copper connectors will fur up which reduces the voltage they can carry or interups the data signals on the data bus.
MPG loss on a 4.4 will be less than a whole percent, it would be different if you had a 1L. You also wont get steamy windows, mouldy leather etc.
Post #37223 20th Nov 2010 8:31pm
Nickj
Surley alternator would eventually result in dead battery. Had this prob for a while but never had issue starting/ or low battery related problems . Will get alternator tested. Is there a certain voltage the RR should achieve??
Post #37230 20th Nov 2010 8:40pm
Page 2 of 4 <1234>
