Home > Technical (L322) > Black Smoke TDV8 How much is too much? |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 |
Diesels always has a puff when you throttle it hard, but it should subside in one or two seconds.. If it's leaving a massive cloud constantly under heavy acceleration, I'd be searching for a split hose.. Either that, it's running rich, or you may have a problem..
9th Oct 2015 7:17pm |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
why didn't your mechanic take them off ,its a 2 minute job ,
9th Oct 2015 7:21pm |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 251 |
Well my smoke stays all the way to 180 kmh, at least that's what I noticed today.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
If you can see it in your mirrors then its too much.
10th Oct 2015 7:16am |
It is only two top ones that need addressing or there is more? |
10th Oct 2015 8:07am |
It seems to be the 2 top ones that split and cause the smoke and would be the first thing to eliminate as it's quick & cheap & they will go anyway at some point, so not much to lose by doing that first |
10th Oct 2015 8:17am |
