![]() | Home > Technical (L322) > TD6 2004: Very slow acceleration |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Check the small pipes to the vacuum reservoir on the inside wing above the turbo. If they are cracked, perished or come off then it wont pull under a heavy load.
Fuel pump fubar'd I would imagine... |
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
replace fuel filter and then check inline pump under L.H rear floor infront of rear wheel |
Back in the day, when owners used to put petrol in TD6's by mistake! It used to |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
Thank you, guys. I have searched based on your advice and read some of the other threads. My symptoms seem to be consistent with the secondary fuel pump failure. I have ordered a new one and will keep you updated.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Hopefully you've sorted it but I had exact same symptoms as you which turned out to be bad fuel.
Ensure to do the filter also, or else you will be doing another pump in a few months! |
I replaced the filter last week with no difference in performance. Today the pump finally arrived, which I replaced without much difficulties thanks to the instructions in the wiki here. This solved the problem and the car runs fine again.
