Home > Technical (L322) > TD6 2004: Very slow acceleration
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Hi there,
Suddenly my car has lost power under acceleration. The engine starts normally without any strange sounds. In neutral the engine revs normally, it seems to be under load that I lose speed. When I (finally) come up to speed it drives normally under 2000 rpm. It feels like the engine is starving from lack of air or fuel.
Hopefull, someone finds these symptoms familiar and can help me in the right direction.
Thanks ! ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #348788 21st Sep 2015 3:30pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Check the small pipes to the vacuum reservoir on the inside wing above the turbo. If they are cracked, perished or come off then it wont pull under a heavy load.
Also check turbo hoses for any splits, etc.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #348812 21st Sep 2015 6:35pm
Fuel pump fubar'd I would imagine...
Post #348839 21st Sep 2015 8:55pm
chaybra
Australia 2006 Range Rover Vogue Td6 Zambezi Silver
replace fuel filter and then check inline pump under L.H rear floor infront of rear wheel
Post #348860 21st Sep 2015 11:33pm
Back in the day, when owners used to put petrol in TD6's by mistake! It used to Censored up the pumps. I can't remember which pump used to give your symptoms... One used to stop it starting, one stop it running and one stop it revving... Maybe do some googling as to which pump does what sir... Thumbs Up
Post #348866 22nd Sep 2015 7:09am
le25dse
Thank you, guys. I have searched based on your advice and read some of the other threads. My symptoms seem to be consistent with the secondary fuel pump failure. I have ordered a new one and will keep you updated.
Thanks Smile ----------
Post #348941 22nd Sep 2015 2:54pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hopefully you've sorted it but I had exact same symptoms as you which turned out to be bad fuel.
Car reved free in neutral. But soon as in gear it had no power and would only rev to around 2800 max.
Drained tank. Changed filter and all ok!
Dunno if any help
Tel Accept, some days your the pigeon, some days your the statue!
Post #348966 22nd Sep 2015 4:58pm
chaybra
Thanks Smile
Ensure to do the filter also, or else you will be doing another pump in a few months!
Post #349187 24th Sep 2015 1:29am
le25dse
I replaced the filter last week with no difference in performance. Today the pump finally arrived, which I replaced without much difficulties thanks to the instructions in the wiki here. This solved the problem and the car runs fine again.
Thanks everybody for your posts. ----------
Post #350779 5th Oct 2015 5:43pm
