Home > Technical (L322) > ff gave me a heart stopping time |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Ahh, the Death Bong, don't you just love it, NOT
21st Sep 2015 2:50pm |
saucyboar5 Member Since: 08 Sep 2015 Location: Staffordshire Posts: 20 |
Here's what is happening now on the on board diagnosis at 3.000 rpm in park..look at the battery volts.. :
21st Sep 2015 5:28pm |
Me thinks your alternator is fubar'd If your lucky it could turn out to be the brushes which are a cheap fix, I would talk to someone who rebuilds them, and keep everything crossed Yesterday I couldn't spell Engineer... Today I are one!
21st Sep 2015 5:54pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8622 |
Yep that looks goosed. If you are v decent with the spanners then it's do-able, if not then it's a general garage job. There is nothing that can't be fixed with a hammer😜😜
21st Sep 2015 6:38pm |
Had the AA out...battery ok...charging on his meter 13.5 v
21st Sep 2015 7:16pm |
I take it you've double checked the battery terminals? I had a very similar incident when the negative terminal was loose.
21st Sep 2015 7:52pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
13.5 volts is not good?????
21st Sep 2015 8:52pm |
13.5 volts is the minimum that the battery will charge, but the on board says it's 12.5 volts which is no good to man or beast. It could just an issue with the voltage regulator, and changing the brush pack will sort it, or it could be a lot worse and some of the windings have failed.
21st Sep 2015 10:24pm |
This may help you, http://www.rrsport.co.uk/forum/post269863.html
21st Sep 2015 10:31pm |
Do not get it repaired!!! It's a bas of a job to get the alternator off and a brand new denso unit (not exchange) from Dan is less than 200 quid
22nd Sep 2015 7:02am |
Well its going to hospital on Saturday ...I will post an update when I have the answer.. First rr..I'm loving it at the moment until the bongs kick off.. |
22nd Sep 2015 6:06pm |
