Home > Technical (L322) > ff gave me a heart stopping time
saucyboar5
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Sorted cheers.. well the profile the ff is still acting like a sulking child First rr..I'm loving it at the moment until the bongs kick off..
Post #348779 21st Sep 2015 2:34pm
miggit
Ahh, the Death Bong, don't you just love it, NOT Evil or Very Mad
I have gotten to loath that sound, does anyone know how to change it? the ring of a cash register would be more appropriate Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #348782 21st Sep 2015 2:50pm
saucyboar5
Here's what is happening now on the on board diagnosis at 3.000 rpm in park..look at the battery volts.. Big Cry Big Cry :
blub: First rr..I'm loving it at the moment until the bongs kick off..
Post #348801 21st Sep 2015 5:28pm
miggit
Me thinks your alternator is fubar'd Sad If your lucky it could turn out to be the brushes which are a cheap fix, I would talk to someone who rebuilds them, and keep everything crossed Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #348808 21st Sep 2015 5:54pm
Yep that looks goosed. If you are v decent with the spanners then it's do-able, if not then it's a general garage job. There is nothing that can't be fixed with a hammer😜😜
Post #348813 21st Sep 2015 6:38pm
saucyboar5
Had the AA out...battery ok...charging on his meter 13.5 v
Here's the list of the diagnosis computer..and yes he ain't got a clue😬😬😬
P117e...fuel quantity malfunction.
C401...Can message engine control unit
U2023...can bus signal
B1001...transponder key.
U040010...unknown fault.
U0416...vehicle dynamics control unit
Any ideas peeps.. First rr..I'm loving it at the moment until the bongs kick off..
Post #348821 21st Sep 2015 7:16pm
dan_uk_1984
I take it you've double checked the battery terminals? I had a very similar incident when the negative terminal was loose.
Grab hold of the connectors and give them a good yank - if they come off in your hand (giggidy) that's not good.
D
Post #348828 21st Sep 2015 7:52pm
wealy
13.5 volts is not good?????
Needed to be 14.2 - 14.4 minimum
Post #348838 21st Sep 2015 8:52pm
miggit
13.5 volts is the minimum that the battery will charge, but the on board says it's 12.5 volts which is no good to man or beast. It could just an issue with the voltage regulator, and changing the brush pack will sort it, or it could be a lot worse and some of the windings have failed.
I had an alternator that was putting out the red light on the dash but only producing a few amps and 12 volts. But the only way you'll know is to get it tested on a proper test rig, I'm sure that someone rewinds alternators in Staffordshire, and providing that the bearings haven't given up and smashed everything (making it fubar'd), a repair will be a lot less dosh than a replacement Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #348854 21st Sep 2015 10:24pm
miggit
This may help you, http://www.rrsport.co.uk/forum/post269863.html
I know it's a different car but the engine is the same Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #348855 21st Sep 2015 10:31pm
wealy
Do not get it repaired!!! It's a bas Censored of a job to get the alternator off and a brand new denso unit (not exchange) from Dan is less than 200 quid
I wouldn't want to risk remanufactured at that price.
Post #348865 22nd Sep 2015 7:02am
saucyboar5
Well its going to hospital on Saturday Sad ...I will post an update when I have the answer.. First rr..I'm loving it at the moment until the bongs kick off..
Post #348976 22nd Sep 2015 6:06pm
