Home > Technical (L322) > Headlights Dazzling
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Headlights Dazzling
Hi All,
Had my first long Journey in the Dark last night up the M6. To say a lot of people where less than impressed is an understatement!
As I passed people I can see the adjusting the mirrors, Even a Disco coming toward me flashed assuming I had full beam on. Looking at the line of the headlight as I pass a Van the top of the beam seems to sit Just below the Drivers window.
Obviously if your in a Van thats fine but in anything lower your getting a whole FFRR HID in the eye!! The car has passed an MOT so assume the level is fine for front on but the beam pointing to the left form the drivers side I think seems to be high.
Has anyone else had this experience?
Post #346826 9th Sep 2015 10:00am
Lots complain about it Rolling Eyes
The two options you have are to A, have them adjusted VERY low! Or B, flick the adjusters inside to european use... This will flatten the beam pattern and stop you dazzling anything to your left side sir Thumbs Up
Post #346828 9th Sep 2015 10:08am
Mcnallykev
Excellent, Thanks Craig. Is the switch in the same location as my old Jag S type R? Top of the headlamp unit?
Post #346831 9th Sep 2015 10:12am
plastic bulb cover thingy off then a lever next to the square xenon bulb unit sir Thumbs Up ... Plenty of vids on youtube i would guess?
Post #346834 9th Sep 2015 10:16am
This may help?
http://www.fullfatrr.com/forum/topic22048.html?view=next
Post #346836 9th Sep 2015 10:18am
Just found this too... Thumbs Up
Tourist Lever
On all headlamp variants a tourist lever mechanism is located on the side of the projector module. This mechanism moves a flap to blank off a portion of the beam spread to enable the vehicle to be driven in opposite drive hand markets without applying blanking decals to the headlamp lens. The position of the tourist lever varies between headlamp variants and drive hand markets. The following lists detail the lever location and positions for home and opposite drive hand markets.
Halogen Headlamps
UK LH side headlamp: tourist lever on the grille side
UK RH side headlamp: tourist lever on the grille side
ROW LH side headlamp: tourist lever on the grille side
ROW RH side headlamp: tourist lever on the grille side
For RH side lamps, the tourist function is operated by pushing up the lever. The delivery condition is with the tourist lever pushed down. For LH side lamps , the tourist function is operated by pushing the lever down. The delivery condition is with the tourist lever pushed up
Bi-Xenon / AFS Headlamps
UK LH side headlamp: tourist lever on the fender side
ROW RH side headlamp: tourist lever on the fender side
For all xenon and AFS headlamp variants the tourist function is operated by pushing the lever down. The delivery condition is with the tourist lever pushed up.
Post #346837 9th Sep 2015 10:21am
Mcnallykev
Brilliant Thank you! Just gone out to to move the lever and guess what happened?
Open the door pull ht bonnet release lever and....
something snapped. The lever has come off the wheel thats turns the cable to release the catch!
Please tell me this is common and an easy fix?
Post #346838 9th Sep 2015 10:29am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Has it snapped Under the bonnet or Inside the car? Ours snapped Inside the car but the cable shot Inside the engine compartment, it was a dealer job to replace the cable as there is no way to open the bonnet, unles someone here knows a method.
Post #346874 9th Sep 2015 3:04pm
Mcnallykev
It has snapped inside the car. The Cable is fine but the Lever has snapped off it's retainer. Is that what happened to you?
Post #346876 9th Sep 2015 3:30pm
this any good Kev?
http://www.fullfatrr.com/forum/topic29319....nnet+cable ... - .- -.
Post #346878 9th Sep 2015 3:54pm
PaulTyrer
No, on ours the cable snapped where it enters through the bulkhead, if you can still grab the inner cable you'll still be able to open the bonnet.
Post #346887 9th Sep 2015 5:25pm
Mcnallykev
Thanks Paul & Stan, I will see how much LR quote for a replacement and then take it from there. Will let you know. The Cable is still attached to the mechanism so hopefully I will be safe!!
Post #346900 9th Sep 2015 6:58pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
When you have fixed the bonnet cable (and that is easy if its broken at the handle. World of Censored if its the bonnet catch end!) I wouldNOT do the tourist thing as a) it won't pass it's MOT next time and b) it is such an easy fix to do the job properly? It is an adjuster on the top of the light fitting and all you have to do is mark a line on your garage doors or wall and wind it down with a long series Allen key.
Do it properly, and stop annoying other oncoming discos !! Rolling Eyes
Post #346956 10th Sep 2015 6:52am
Lost for Words
It's not an MOT failure to have a flat beam as long as it still won't cause dazzle.
Quote:
A flat top or other alternative headlamp dipped beam pattern (not being one of the examples) is acceptable providing all of the beam upper edge, including any “peak” is contained within the appropriate tolerance band.
I agree on adjusting it properly though anyway.
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #346966 10th Sep 2015 9:31am
Mcnallykev
Ace thanks guys. Will adjust properly. Thanks for the advice!
Post #346967 10th Sep 2015 9:34am
