Home > Technical (L322) > Headlights Dazzling |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Lots complain about it
9th Sep 2015 10:08am |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
Excellent, Thanks Craig. Is the switch in the same location as my old Jag S type R? Top of the headlamp unit? |
9th Sep 2015 10:12am |
plastic bulb cover thingy off then a lever next to the square xenon bulb unit sir ... Plenty of vids on youtube i would guess? |
9th Sep 2015 10:16am |
This may help?
9th Sep 2015 10:18am |
Just found this too...
9th Sep 2015 10:21am |
Brilliant Thank you! Just gone out to to move the lever and guess what happened?
9th Sep 2015 10:29am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Has it snapped Under the bonnet or Inside the car? Ours snapped Inside the car but the cable shot Inside the engine compartment, it was a dealer job to replace the cable as there is no way to open the bonnet, unles someone here knows a method. |
9th Sep 2015 3:04pm |
It has snapped inside the car. The Cable is fine but the Lever has snapped off it's retainer. Is that what happened to you? |
9th Sep 2015 3:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35273 |
this any good Kev?
9th Sep 2015 3:54pm |
No, on ours the cable snapped where it enters through the bulkhead, if you can still grab the inner cable you'll still be able to open the bonnet. |
9th Sep 2015 5:25pm |
Thanks Paul & Stan, I will see how much LR quote for a replacement and then take it from there. Will let you know. The Cable is still attached to the mechanism so hopefully I will be safe!! |
9th Sep 2015 6:58pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
When you have fixed the bonnet cable (and that is easy if its broken at the handle. World of if its the bonnet catch end!) I wouldNOT do the tourist thing as a) it won't pass it's MOT next time and b) it is such an easy fix to do the job properly? It is an adjuster on the top of the light fitting and all you have to do is mark a line on your garage doors or wall and wind it down with a long series Allen key.
10th Sep 2015 6:52am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
It's not an MOT failure to have a flat beam as long as it still won't cause dazzle.
I agree on adjusting it properly though anyway. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
10th Sep 2015 9:31am |
Ace thanks guys. Will adjust properly. Thanks for the advice! |
10th Sep 2015 9:34am |
