Home > Technical (L322) > Strange Beeping
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
Strange Beeping
Morning...
So, returned from shopping last Saturday around lunchtime, unloaded FF and the car didnt get used until the Monday morning for work. However, on the Sunday evening i noticed i had not locked the car after the shopping trip!!! Shocked Shocked Shocked Shocked Embarassed
I locked the car but 2 or 3 mins later the alarm went off, i unlocked the car, then locked it again, but alas the alarm went off again. Tried starting it for a few mins then locking it but alarm still went off. Big Cry Big Cry
So after a sleepless night because i had to leave it unlocked, i went to work the following morning and locked it. Alarm went off once in the day but after unlocking/locking it didn't go off again. Took the liberty of having the battery checked at County Batteries and all is fine. Thumbs Up
So, now when i unlock it (every time) i get 2 beeps, it locks/unlocks fine and the alarm does not go off whilst locked anymore, but i'm constantly getting the 2 beeps each time i unlock. Big Cry
Please help. its embarrassing. Embarassed Whistle
Many Thanks...
 2011 TDV8 Autobiography
Post #343718 22nd Aug 2015 9:25am
Andy B
Hi Pete,
Weird one that Rolling Eyes There is a setting you can change in the CCF to enable/disable the beeps, but you will need an IID tool or similar to make the change....or ask your friendly local Stealer Very Happy
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #343735 22nd Aug 2015 10:48am
BigPete
Thanks Andy,
Any idea why its suddenly started beeping, after 4 months of no beeping?? Confused
Pete 2011 TDV8 Autobiography
Post #343739 22nd Aug 2015 10:56am
ajac8
The two beeps is a door / bonnet open warning but normally you don't get the locked state. Could it be a loose lock sensor? I think the bonnet is the easiest to diagnose but the others are all within the packs contained in the door cards. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #343740 22nd Aug 2015 10:57am
Zirconblue
If one aperture is open (or the car thinks it is), then i think it locks all other doors but not the one it thinks is open. When that aperture is then closed it locks it.
I suppose you could lock it then go around and check that all the doors and boot are locked, that would possibly localise the problem.
Post #343747 22nd Aug 2015 11:07am
Andy B
BigPete wrote:
Thanks Andy,
Pete
No idea Mate I'm afraid. Mine beeps at the moment, but I am about to turn it off as it is annoying me! Evil or Very Mad
From memory I think the setting is in the Body Control Module accessed via the IID tool.
Cheers,
Post #343753 22nd Aug 2015 11:21am
BigPete
Just to clarify, it beeps twice only when i unlock it, it locks perfectly normal and the mirrors fold in as they should. 2011 TDV8 Autobiography
Post #343754 22nd Aug 2015 11:24am
ajac8
Sorry I ms-read. If all functions well now then its just a case of disabling beeps via the CCF's and put it down to another LR anomaly! Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #343755 22nd Aug 2015 11:39am
It beeps twice when you unlock it to tell you the alarm has gone off since you locked it... faulty alarm.... for now, just unplug the alarm horn which is in the opposite place to the main battery on the earlier cars but they may have moved it on later ones... Thumbs Up Pete
Post #343756 22nd Aug 2015 11:41am
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Old thread. But I have the same issues on a 2012 4.4 tdv8.
All locks fine, occasionally beeps but everything locks
But every time you unlock it it beeps.
No fault codes stored so plan to just disconnect the source of the noise. Just need to know where it lives!!!!
Any other suggestions welcomed.
Thanks.
Post #537916 19th Dec 2019 5:01pm
Trantorman
fixed this Very Happy someone had turned it on in the CCF file, so normal order is returned its now switched back off.
Post #538124 21st Dec 2019 5:25pm
