Home > In Car Electronics (L322) > Intermittent tv reception
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi Guys, I have had my 2010MY Autobiography for 3 weeks now and love it. V fast but V quiet! In the garage for a bit of work today that the warranty is covering, two lower arms and a CV joint on the Drivers side (�1019) eeek! It needs a details but other than that only one niggling problem.
The TV is intermittent. Sometimes it works sometimes it doesn't. When is doesn't work the box that you should be able to scroll along on in Auto is just full orange and no Channel No is displayed.
Is there anything I can check?
Post #343080 18th Aug 2015 12:48pm
could be down to location...if the houses around you need an aerial to receive freeview then you have no hope in getting it in the FF..drive to a strong signal area and try there.. ... - .- -.
Post #343082 18th Aug 2015 1:11pm
Mcnallykev
Thanks Stan, It isn't that. If I turn the engine off and lock the doors where it had a signal before the channel number is just
CH-- Nothing.
Any thoughts?
Post #343158 18th Aug 2015 8:24pm
engine off and lock the doors with you inside?
maybe the door locking is powering down the tv antenna amp.. ... - .- -.
Post #343161 18th Aug 2015 8:34pm
Mcnallykev
No I lock from the outside and open again. I just don't get it. I have checked the connections I can see but nothing seems to be loose.
Unless I am missing where it is. It must be a power issue but Where would i start?
Post #343164 18th Aug 2015 8:40pm
dunno.....i can only think that you are not leaving enough time for the ecu's to power back up.. ... - .- -.
Post #343166 18th Aug 2015 8:48pm
Mcnallykev
I don't think so. I can leave it over night and it either works or it doesn't??
Post #343172 18th Aug 2015 9:17pm
Are you in the Clyde valley when you're checking this? I would be surprised if you got any signal at all to be honest. Got - 2017 SDV8 Autobiography in Loire Blue
Post #343187 18th Aug 2015 10:45pm
Mcnallykev
I am at the top of it and the signal is a bit iffy but still I think the fact there is no channel number is the thing. It doesn't matter where I drive to if it has decided not to work it won't work anywhere.
I thought it may be a damaged cable but surely it would never work if that where the case and when it does work it is perfect.
Post #343222 19th Aug 2015 6:39am
you could check the left rear cubby for loose cinnections and maybe water ingress.. ... - .- -.
Post #343229 19th Aug 2015 8:24am
Mcnallykev
I have had a fiddle but I;m not sure which one the TV tuner is. Will keep digging around.
Post #343286 19th Aug 2015 2:37pm
Mcnallykev
Hi all, Hope you had a good weekend. This TV thing is still happening. I am making a few assumptions in that it can't be a damaged fibre optic as it wouldn't work at all. So it must be a loose cable. Can someone confirm which unit in the left hand of the boot is the TV tuner and any other leads I should check?
Incase I haven't said already it is a MY2010 Autobiography SC Very Happy Very Happy Very Happy
Thanks
Post #344082 24th Aug 2015 9:51am
Your box will look like this sir Thumbs Up
http://www.ebay.co.uk/itm/Range-Rover-Spor...3cff8e7fe8
Post #344249 25th Aug 2015 12:54am
Mcnallykev
Thanks Craig. That's cheap isn't it! Shocked Shocked Shocked
Post #344271 25th Aug 2015 7:38am
T24RES
If you have a warranty, why not ask the garage to take care of it? Ian
Post #344273 25th Aug 2015 7:52am
